Left handlebar switch
  • Padre4art
    • Oct 2016
    • 62
    • Chambersburg, Penn.
    Ok. Foiled again. Installed a nice set of handlebars on the F today, and once again turn signals are dead. Nada. Not the fuse. Parking lights work.
    I wiggled the wires coming off the switch and they worked very briefly.
    Has anyone used the left switch forum MikesXS? What's involved?
    Or does anyone have an original they could sell?
    Thanks much!
    Art
    79 F
    Thanks much!
    Art
    Either no ground from bars to switch or switch needs to be taken of bars and cleaned internally and checked for broken solder joint.
    • Padre4art
      • Oct 2016
      • 62
      Hadn't considered grounding to the handlebars. Everyone else, like the horn, and hi low beam switch works fine.
      Any other clues?
      Anyone use the xs650 switch gear?
      79 F
      • donebysunday
        • Oct 2012
        • 1737
        • New Berlin, Wi.
        Thanks much!
        Art
        Sounds like the good old solder has lost it's grip ?
        If you don't solder the wires back on I'll do it, send it to me.
        PM me !
        76 XS650 C ROADSTER
        80 XS650 G Special II
        https://ibb.co/album/icbGgF
        80 XS 1100 SG
        81 XS 1100LH/SH DARKHORSE
        https://tinyurl.com/k6nzvtw
        AKA; Don'e, UD, Unca Don'e
        • Padre4art
          • Oct 2016
          • 62
          Thanks for pointing out the solder problem in the left control. Yep! 3 loose wires in the bottom. Bought myself a solder gun at big box store, and went to town. Fix requires at least three hands! One to hold the wire, one to hold solder, one to hold gun. Anyway, it's back together and working!
          79 F
            Good to see you resolved the issue Padre!
            • donebysunday
              • Oct 2012
              • 1737
              • New Berlin, Wi.
              Awesome
              put another feather in your hat !
              76 XS650 C ROADSTER
              80 XS 1100 SG
                • 7817
                That's great! another skill you didn't know you had until you tried!
