I replaced the intake manifold boots and cleaned the carbs and adjusted the valve clearances.
I have decided to delete the octy.
I am re-plumbing the fuel lines with clear Tygon.
There are hoses dangling at the moment.
1. Large diameter breather hose from the rear of the engine/transmission.
2. Skinny diameter breather hose from very near to the large diameter hose.
3. Medium diameter breather hose from the bottom of the air box.
4. Sensor hose from a sensor below the fuel tank.
I assume that one or more places are capped or plugged due to the absence of the octy.
Where do the dangling hoses connect? I should have taken pictures before dis-assembly.
