Sebastian's Bike Restore
    replied
    That sounds like a stuck, rusted, detent ball and spring. Soaking the whole control in Evaporust will clean it up.
    Vinegar will work too but it eats good metal. You'd have to take apart the control and do some light scrubbing to get rid of the rust and pick out the ball/spring. When they're clean, soak everything in a baking soda bath to neutralize the vinegar and rinse with clean water.
    Leave a comment:
    replied
    From when I was helping him last week: The switch doesn't even rotate, it's just kind of wiggles back-and-forth and randomly closes the circuit. Idle vibration alone will cause it to kill the engine, as when sync'ing...
    I did fix one by taking it apart and using JB Weld put the pieces back together on an 80G that I fixed up and sold. I took the one on my SG apart for a model and reference. It took patience and time.
    Just get the one I posted (post 56) in that eBay link and be done! You will be happy you did. If you ordered it, it would be on the way to you already!
    Leave a comment:
    replied
    Sebastian, did you take the kill unit apart and try to clean all of the contacts? If you want to try, be careful because thre is a spring and ball to make it click into positions. I still have original parts and it works.
    Leave a comment:
    replied
    Sebastian, open up the right-hand control and you'll see the Stop/Run switch and the two Red/White wires.
    Twist the two Red/White wires together and tape them, then put the control back together.
    The two wires have to be connected together, by hand or the switch, because they're the first part of the ignition circuit after the 10A IGN fuse. The Stop/Run switch 'kills' the ignition by opening the circuit so there's no power to the coils, TCI, or the Start solenoid.
    Leave a comment:
  • Sebastian_99
    replied
    How would I go about bypassing the Kill switch? I'm fine with not using it for a while
    Leave a comment:
    replied
    Originally posted by Sebastian_99
    I'm wondering if a simple toggle switch would be a decent replacement?
    It would work in a pinch, but if you make modifications to the wiring connectors for that and then try to mount a stock one, you may wish you hadn't. For example, snipping off ring connectors and stripping back the insulation is going to shorten the wires.
    To tell you the truth, I virtually never use the kill switch. You decide, but if it was my bike, I would bypass it until the correct switch arrived in the mail.
    Leave a comment:
  • Sebastian_99
    replied
    Originally posted by Bonz
    Is the one on my 1980 special going to quit in six months? Will the one on Greg's bike or CaptonZap's or Scott's bike quit in six months? I gather you are simply trying to say it's not a potential long-term fix like new stuff would be. I'm not trying to be pessimistic, however I would have decent faith in a used part simply because many bikes have the original ones without problems.
    Sebastian, here is one on eBay with free shipping. You need to get one on there and counting on Action Cycles to have one is going to be the same as getting this from eBay delivered to your house.
    https://www.ebay.com/i/152562140250?...D1232879853088
    Leave a comment:
  • Sebastian_99
    replied
    For the kill switch, look at mikesxs.com for a new assembly, and put your plugs/wires on it. The plastic inside the kill switch falls apart, as in a LOT of little plastic bits! Your only 2 ways to fix it is bypass or new. A used one will start to break after about 6 months if it's from an early '80 model.
    The fairing connector you can get at radio shack or any good electrical store. Pretty easy for some of us to help with the wiring, so I say bonz can probably help.If not, I will be at the rally and can look at things then.
    DiverRay,
    I appreciate the offer but I'd prefer to head to the rally with an operational headlight, just in case ya know!
    If there are any radioshacks still open I'll pick those connectors up.
    Leave a comment:
    replied
    Leave a comment:
    replied
    Leave a comment:
  • Sebastian_99
    replied
    Bike is firing up well from cold start. I'm getting a little bit of hesitation when I hit the throttle but I think that should get resolved by tightening the throttle cable. The last thing I have to do is square away the wiring from the bike to the fairing. Unfortunately the wiring harness I bought from Andreas doesn't fit with the female end on the fairing. Gonna see if I can find two new 9 pin clips that I can wire in. Then I just have to figure out what goes to what. Electrical, my favorite! Haha.
    It's not looking like I'll have the rear turn signals squared away by the rally but I've always used hand signals anyways so I should be good.
    I have to figure out the Kill switch issue, not sure what the problem is but I may be able to get a new assembly from one of the bike junkyards in Colorado Springs (action cycles).
    Leave a comment:
    replied
    ^^ Good one! ^^
    Leave a comment:
    replied
    Heh, Quincy would be a fine moniker if the bike regularly came up with its own astounding solutions to the problems in its episodic drama instead of causing them.
    Leave a comment:
    replied
    Silly me, after I thought of Quincy, I saw your signature line...
    Leave a comment:
    replied
    Thanks, I had to clean the brass on the floats so the solder would stick and from there it took on a life of its own.
    The XJ is, "Baby."
    She is my baby and it's also a play on the XJ's freaky linked brake system, as in, "No one puts Baby in a corner."
    Leave a comment:
