gas in air filter
  • speedlimit85
    • Jan 2017
    • 434
    • Gainesville, Fl.
    gas in air filter
    A couple years ago I got the rebuild kit from mikes xs and did the work without removing the carbs from under removing the float bowls.
    How long/ many miles should these parts last?
    Today, I am ordering from partzilla costing twice as much.
    25G-14107-20-00 NEEDLE VALVE SET
    2H7-14451-00-00 ELEMENT,AIR CLNR
    3F7-14984-00-00 GASKET,FLOAT CHMBR
    3F7-14991-00-00 PLUG
    Am I missing parts to repair gas leaking in air filter on starting?
    Thanks
    80 G
  • MPittma100
    • Aug 2011
    • 2359
    Leaking
    Thanks
    Should never have fuel in air filter. Pull carbs off to work on them. Put fuel to all carbs before disassembly and see which ones are leaking. Disassemble and clean thoroughly. Put in new parts and adjust float levels to specs. The parts you ordered should help solve the leak. But could be as simple as an incorrect float level adjustment.
    Put fuel in all carbs while on bench and verify that there are no fuel leaks. Once satisfied, reinstall and sync.
    Key to success is to stop/repair all leaks prior to installing onto engine.
    Don't forget to check for fuel contamination of the engine oil prior to running engine.
    1981 XS1100H Venturer
    K&N Air Filter
    ACCT
    Custom Paint by Deitz
    Geezer Rectifier/Regulator
    Stebel Nautilus Horn
    EBC Front Rotors
    Limie Accent Moves On In 2015
    Mike
      • 5062
      Also consider your vacuum operated petcocks. If you ever replace the holey gaskets, it is very advantageous to sand and polish the valve handles on the contact surfaces and round the hole edges so that they are not sharp. Your holey gaskets will last a long time if you do that. This there is also a plunger and seat in the petcock and you might want to polish the seats for the plunger.
      • speedlimit85
        • Jan 2017
        • 434
        • Gainesville, Fl.
        fixed
        I was able to get a float valve assembly and install from under one carb. It's running great. This is not the proper method. I understand.
        80 G
          • 5062
          You can't argue with success!
            • 3237
            Cheers to you! Good job!
            ZRX1200
            Seca 750
            • speedlimit85
              • Jan 2017
              • 434
              • Gainesville, Fl.
              #2 carb
              So I'm thinking the # 2 carb gets worn sooner with the extra vacuum hose. The O- ring around the float valve holder on the #2 carb was where the gas was leaking from.
              80 G
                • 3237
                I don't follow that at all? The carb is creating vacuum anyway you look at it. Doesn't matter if it has one or a hundred hoses coming out of any one carb.
                ZRX1200
                Seca 750
