I've got a big bore piston kit recently broken in on my '79. It runs great except for one thing: it pings on hard acceleration in top gear, running on 93-octane fuel.
I noted that the big bore pistons are based on the later versions, and have more of a dome than the standard '78-79 pistons, so that plus the bigger bore obviously means the engine is running more compression.
I've retarded the ignition timing a couple of degrees to little effect. Is anyone else running this combination? I'd like to know if there is a sweet spot for ignition timing.
. Thus the cams, higher redline ECU, double valve springs, higher compression pistons and base gasket delete along with larger carburetors on my ZRX 1200. However, because the ZZR 1200 and ZRX 1200 are the same engine from the head down, bolting on all of the ZZR parts together is a known system.
