I disassembled all the handle bar switches and soaked them over night in Evaporust to clean everything up. As I started to put it all back together, noticed a brown wire with a white stripe that is not soldered to anything.
[IMG]
[/IMG]
It appears as a result of handling the assembly that the wire is sticking through the small bracket that fastens the horn button in place in the switch housing. Here is another shot after pulling that wire from the small bracket.
[IMG]
[/IMG]
It appears that this wire was originally soldered to the 4-way switch just to the right of the dark brown (or black?) wire which is just to the right of the solid brown wire as seen in the picture? I don't want to ignorantly re-solder this wire in the wrong spot!
Wasn't having much luck searching for a wiring diagram for an "H" (not sure I could have read it even if I did find it
I'd greatly appreciate it if someone could steer me in the right direction here.
[IMG]
[IMG]
