Bleeding Front Brakes
  • Filter
  • Bleeding Front Brakes
    I realize there are lots of threads concerning this subject, but I thought my experience may be helpful to some.
    The brake fluid in my recently acquired '81 Special looked like red mud. I drained it all out and blew air through the lines. I cleaned the "spooge" hole in the master cylinder, and then filled it with new fluid. I started out trying to bleed the front brakes the same way I had bled brakes on other vehicles - nothing. I took the lines off the calipers (one at a time) - no fluid was getting through. I then tried to suction the fluid through - still no luck.
    I thought then I would try "from the bottom up" - using the suction tool in reverse. Still nothing. I came back to this site and realized that I had probably compressed the brake lever too far. I tok the master cylinder apart, and sure enough I had dislodged the seal on the piston. I put the seal back where it was supposed to be and assumed that all would go smoothly - not yet! I still wasn't able to get any fluid done to the calipers.
    Running out of ideas, I emptied the resevoir again to check the spooge hole - and it was plugged again. I guess when I pumped air/fluid in reverse it dislodged some gunk and plugged it. I cleaned it for the second time, and had the brakes bled and functioning well in about 15 minutes.
    I pumped quite a bit of fluid through to make sure I got most of the crap out - took it for a test drive & the brakes worked great.
    Chlanna Nan Con Thigibh A So's Gheibh Sibh Feoil
  • #2
    Keep an eye on your front rotors for heat buildup over the next while. It sounds like there is still 'stuff' in the lines that could plug the spooge hole again. If that happens, the brakes will start to drag, the rotors will get hot, and you know the rest. Whenever I work on the brakes on any of our various XS11s, I make a point of checking the rotors for heat buildup every time I stop the bike for the next week or two. It only takes a second and you will become ver familiar with how cool the rotors should feel.
    • #3
      Thanks for the tip - I will check them over the next few weeks.
