Want to get bigger carbs...need suggestions.
  • NorCoaster
    • Sep 2015
    • 90
    • Mpls
    Just as the title implies...I'm looking for something bigger than the 34s...or maybe just larger jets? Am gonna be swapping an 850 FD on along with putting on pod filters this summer and would like to be able to get more fuel to spin that FD a little quicker. Also, I'm planning on doing the 2nd gear mod and want to throw a big bore kit in her too within the next year or two...my end goal is to be able to hit 150+mph...
    XS1100SG "Lucy Ferr" - Build project. Biltwell Tracker bars, octy delete, rerouted breather hose, mini turn signals, bar end mirrors, TC's fuse block, TKAT fork brace. No fairings. No windscreen. No hard bags. More to come...eventually...
    • 7863
    Uh.....
    What you're saying is that you want to waste a bunch of money on a lost cause. Search the forum, and good luck!
    Peace
      Uh.....
      Peace
      A big +1!......but who knows, maybe he'll figure that out before too much waste is thrown out there.
      Could just throw him a bit of a clue and leave out the proven proof, such as for starters, 150mph aint' happenin.
        • 3231
        150 mph plus, XS1100? With that said, if it was possible what road are you going to do that on? Make sure you let me know so I am off of it to avoid the Flexi flyer chassis headshaking its way to oblivion.
        Do I read it right, you are asking if using larger jets somehow would equate to larger carburetors?
        The way you have stated the post makes me, with respect, ask if you may have the understanding of things in order to try and pull this off.
        In any case, as JetMech said, search terms just like the wording you put in the first post. You'll turn up lots of stuff.
        The reality is the XS1100 does not "hop up" appreciably. All manner of improvement has been tried in 39 years of existence.
        ZRX1200
          • 7738
          OK, it IS possible, but NOT probable to hit 150 on these bikes. The 850 FD mod will get you close, IF you can hit redline in 5th gear.
          I'm just getting ready to start putting together my '78 engine. It has the big Wiesco kit, 1192cc IIRC, as well as the head and new valves. I also have the crank and rods that have been worked on from A.P.E. in SoCal, to the tune of $850 a few years ago! It is balanced to 14K RPM's, but with all that, I'll still need fuel injection and a turbo to hit 150. So yeah, it can be done but just how much time and money do you want to throw at it.
          • MPittma100
            • Aug 2011
            • 2359
            Carbs + a lot more
            You would need in the area of 165-185 horsepower to start with. And about 10-12k RPM with the math of the final gear ratio in 5th gear. Get that and you will make your goal.
            May want to look at something in the area of a K1200 GT or the likes.
            1981 XS1100H Venturer
            K&N Air Filter
            ACCT
            Custom Paint by Deitz
            Geezer Rectifier/Regulator
            Stebel Nautilus Horn
            EBC Front Rotors
            Limie Accent Moves On In 2015
            Mike
            • Rasputin
              • 3189
              • Lacombe, Alberta, Canada
              One of my bikes will hit 135MPH according to it's speedometer (and I am not sure it is trustworthy). I highly doubt that even with the rear change anyone will hit the 150MPH mark without it being towed by a top fuel dragster.
              Something like (but probably not in this case) Wallace racing calculators would be able to show you how insane this could be. You would have to enter all the info from volumetric efficiency to tire size to figure it out
              Basically if you want to invest enough to do this, show us the math that it can indeed be done. Then hope to god you are able enough to handle the bike at that speed. Trust me at 135MPH that bike is unstable to say the least. It is getting better with new suspension and the TKAT fork brace helped as well as every bearing being replaced.
              Yes you can do every mod known and turbo it etc, but at what cost? Far better off to buy the bike that does what you want than to modify one of these enough to even try.
              Make sure your insurance is paid up to date and your brakes are in perfect shape. Also please take a change of underwear with you!
              2-79 XS1100 SF
              2-78 XS1100 E Best bike Ever
                • 5061
                Horsepower is torque x rpms x a constant. I could be wrong, but it seems that the gearbox change requires more torque and therefore the upper rpms are compromised because there is only so much HP available. I seemed to get more zip out of the bike from the stock gearbox. Turbo. That is the answer. It works for my F150. Honestly, the gearbox change is more of a comfort thing while on the interstate.
                • donebysunday
                  • Oct 2012
                  • 1737
                  • New Berlin, Wi.
                  That's fast
                  NITROUS !
                  YES that should give you a laugh even if you don’t make 150MPH., you don’t care if it hurts it's just so damn funny.
                  76 XS650 C ROADSTER
                  80 XS650 G Special II
                  https://ibb.co/album/icbGgF
                  80 XS 1100 SG
                  81 XS 1100LH/SH DARKHORSE
                  https://tinyurl.com/k6nzvtw
                  AKA; Don'e, UD, Unca Don'e
                    • 9980
                    Food for thought, larger carbs won't make the intake ports, intake valves, exhaust valves, or exhaust ports any larger.
                    Picture an hour glass.
                    The Jap engineers have already squeezed nearly 100 HP from a 68ci carbureted engine. Without FI and turbocharging I'm pretty sure that's about topped out.
                    I have a friend who spent thousands of dollars on porting, polishing, cams and other mods on one of these engines and only pulled around 20 extra hp.
                      • 5061
                      There is the issue of red line due to valves "floating" and a lot of other parts that were designed with working stresses. There are xs11 drag bike out there however...
                        • 3231
                        Where is the OP? Sorry if I scared him off with my post.
                        ZRX1200
                          ........Boo!
