DB Electrical Coils? Primary wires arent marked?
  • Kernasaki74
    • Apr 2017
    • 10
    • Columbia, Illinois
    So I bought some aftermarket coils on ebay from "DB Electrical" the primary wires are yellow and black but neither the coil or the wires are marked + or -. The coils came with no instructions or anything. Can anyone help me identify or tell me how too identify which of the wires is + and which is negative? Here is the ebay link to the exact coils I purchased...
    DB Electric offers top aftermarket parts nationwide for auto, boat, and industrial needs. Discover quality and reliability now!
    1979 XS1100
    1976 KZ750 Twin (Project)
    2015 Street Bob
    1978 MX80
    1975 CB550 (Project)
    If those coils are for your listed 79XS1100, they are incorrect ohm coils. The 79 XS1100 uses 1.5ohm coils. The ones your showing are 3ohm coils..
    • Kernasaki74
      • Apr 2017
      • 10
      Yes I bought the 3ohm and will disable the resistor
      1979 XS1100
      2015 Street Bob
      1978 MX80
        They're wasted spark coils. The Secondary voltage fires one spark plug with normal polarity center electrode to ground strap, the other plug fires reverse polarity ground strap to electrode so the Primary polarity doesn't really matter.
        If there are no markings on the coils themselves at the terminals I'd make the Yellow wire the positive and the Black wire negative but it's your bike, pick a color and tell yourself it's the positive lead and the other one's negative.
        Just for grins, swap the two wires every few thousand miles so the two spark plugs will wear evenly.
        • Kernasaki74
          • Apr 2017
          • 10
          Fair enough, i will do as advised short of changing the wires for plug wear, lol...
          1979 XS1100
          2015 Street Bob
          1978 MX80
            Be bold and drive the pettifoggers nutz, use two different color wires for each of the two coils.
              If the coils are not marked + or - , then the polarity should not matter.
              • MPittma100
                • Aug 2011
                • 2359
                Ask
                Website seems to invite questions. I would send a message and ask them.
                1981 XS1100H Venturer
                K&N Air Filter
                ACCT
                Custom Paint by Deitz
                Geezer Rectifier/Regulator
                Stebel Nautilus Horn
                EBC Front Rotors
                Limie Accent Moves On In 2015
                Mike
                  Hey there, My DynaTek coils were ALSO Non-polarity specific, they said it could be wired either way to either primary terminal....so the newer coils apparently don't require a specific polarity, the innards are just a big ole electromagnet....so it doesn't care which way the power gets IN.
                    The inexpensive inductive coils for wasted spark are not sensitive to Primary polarity. If the coils are marked it's so the techies don't get lost while they're trying to trace ignition wires and earn a living, not because the coils or the spark plugs really care about polarity.
                    Remember, the electrons have to complete the circuit through the cylinder head too, not just the coil. Here are the possible 4 cylinder wasted spark electrode polarities so the head doesn't run out of electrons for the ignition system:
                    Street and Circle Track (NASCAR)
                    1(+) 2(+) (-)3 (-)4
                    Antipodean Street and Circle Track
                    1(-) 2(-) (+)3 (+)4
                    Moto GP Weave
                    1(+) 2(-) (+)3 (-)4
                    Antipodean Moto GP Weave
                    1(-) 2(+) (-)3 (+)4
                    • Kernasaki74
                      • Apr 2017
                      • 10
                      Thank you everyone for your replies. I got it all figured out. I assumed the polarity didn't matter but I was having some backfiring issues. I was tired and had been working on it most of the day so I came inside, posted my query and shortly there after went to sleep. I went out this morning and traced the issue to a loose plug cap I over looked. I recounted the coils, rechecked all the wires and she fired right up. Purrs like a kitten now. I will attempt to post a video here shortly.
                      1979 XS1100
                      2015 Street Bob
                      1978 MX80
