Q about octane/no ethanol
  • Bergman16
    • Jun 2014
    • 286
    • New York, N.Y.
    I was very happy to learn through a post here (that led me to pure-gas.org) that a widespread convenience store chain in NYS--Stewarts--sells non-ethanol gas at every station. But, it's only at the 91 octane level. I generally run 87 on the bike, and she runs fine.
    Besides the expense, is there a downside to 91 octane on these old bikes? I couldn't tell any difference on one tank in terms of performance.
    Steve R
    '80 SG
    Former bikes:
    1978 XS400E Red
    1981 XS850 Special (Stingo)
  • speedlimit85
    • Jan 2017
    • 491
    • Gainesville, Fl.
    Non ethanol is 90 or 87 octane here. I've been using 90. Next tank I'll try 87 and let you know if there is a difference.
    80 G
      IMO, run the 87octane. Compression ratio of these motors isn't high enough to justify 91 and higher octane. What it amounts to is, the higher octane fuel ignites a tad later which compensate for high compression ratios, which in itself will cause fuel/air mixtures to ignite a tad sooner.
        • 3372
        In other terms not expressly stated thus far, since higher octane gas ignites later, therefore it will burn later, and in the face of lower compression, will be burning still when the exhaust valve is open and depositing carbon onto the backside of exhaust valves, which can shrink valve clearance and burn an exhaust valve worst-case.
        2001 ZRX 1200
        1982 Seca 750
        1983 Nighthawk 550
        • Bergman16
          • Jun 2014
          • 286
          • New York, N.Y.
          Thanks, I was afraid of something like that. Too bad.
          Steve R
          '80 SG
          Former bikes:
          1978 XS400E Red
            'Too bad'.........naw, tis a good thing. Think of the money not wasted at the pump, or an overheated exhaust valve or two or four.
            • Bergman16
              • Jun 2014
              • 286
              • New York, N.Y.
              yeah...I feel better already!
              Steve R
              '80 SG
              Former bikes:
              1978 XS400E Red
                My bike HATES high octane. Loves the cheap stuff.
                • donebysunday
                  • Oct 2012
                  • 1737
                  • New Berlin, Wi.
                  I myself would rather use the 91 non-ethanol and run a few oz. of MMO every few tanks than that worse for your engine E10 crap.
                  This is exactly what I did with my new 79SF until it was not new anymore 6 years later with 55K on the clock.
                  I sold it to my neighbor, he took it to Mexico once and made the round the great lake trip twice. It ran just fine till he crashed it
                  76 XS650 C ROADSTER
                  80 XS650 G Special II
                  https://ibb.co/album/icbGgF
                  80 XS 1100 SG
                  81 XS 1100LH/SH DARKHORSE
                  https://tinyurl.com/k6nzvtw
                  AKA; Don'e, UD, Unca Don'e
                    • 3372
                    I think you have said it yourself best, you couldn't tell a difference between them in performance. That seems to be a de-facto answer. . Stick with the lowest octane that doesn't knock or ping. The bike should run the best and make the most power.
                    2001 ZRX 1200
                    1982 Seca 750
                    1983 Nighthawk 550
                    • MPittma100
                      • Aug 2011
                      • 2359
                      Decal
                      Decal on bike says to use 89 octane fuel from 1979.
                      1981 XS1100H Venturer
                      K&N Air Filter
                      ACCT
                      Custom Paint by Deitz
                      Geezer Rectifier/Regulator
                      Stebel Nautilus Horn
                      EBC Front Rotors
                      Limie Accent Moves On In 2015
                      Mike
                        That non-ethanol fuel sure is great for bikes that get infrequent use.
                          lucky for
                          us that we have ready access to 87 non ethanol. I also second what Done said about the MMO in the gas tank. I put a couple capfuls in every tank. I notice the difference when on the road and I don't put the MMO in. Valves get louder.
                          • speedlimit85
                            • Jan 2017
                            • 491
                            • Gainesville, Fl.
                            87 no ethanol performs the same as 90 no ethanol. Oddly, 87 costs more than 90.
                            80 G
                              • 3372
                              All things equal 87 octane will you get a little performamce versus 90 octane in the XS. 90 octane burns slower and the XS (and all other engines designed for lower octane fuel) doesn't combust 90 octane as fully before the valves start opening on the exhaust stroke. Interesting that 87 non ethanol costs more than 90 non ethanol. That must be a local thing where you are?
                              2001 ZRX 1200
                              1982 Seca 750
                              1983 Nighthawk 550
