can you use ngk bpr7es? in an 1978 xs standard?
resistor plugs
I figure... the XS had resistor plug caps, so it could use regular plugs... if you have a non-resistor set of caps, you could use resistor plugs....
Resistance should be 5k Ohm. Check it. And the caps you have.
Anyhoo... a set of 4 NGK BP6E plugs is bout 10$ here, so don't worry too much, plugs are cheap.
LPIf it doesn't have an engine, it's not a sport, it's only a game.
