XS11 History
  • mcmotohistory
    • Aug 2015
    • 44
    • Crescent City, CA.
    XS11 History
    I am in the process of puttting together a video history of the XS11. I could use the members help to answer a couple questions I have. I have the list of all the model numbers, but to be sure, 1. the midnight special XS1100LG , and XS1100LH were only made only in 1980 and 1981, yes? 2. Is there any difference between the two years of Midnight Special where you could tell one year from another? 3. Slotted disc brakes means 1980 or later. 4. 1981 is the only year there was a little slash on the side covers under eleven special? 5. The 1981 XS1100H Venturer was the only model that came stock with a oil cooler? 6. In 1979 the XS1100SF Special comes in "Black Gold" from the factory. Is that just Black?
    Further I need help telling the difference between, 1978 "Macho Maroon" ,1979 "Magenta Red" , 1980 "New Ruby Red" , there is a color on the 1980 special listed as "Black Red" what is that? , the 1981 special lists "Black Blue" is that like the "Indigo Blue" on the Venturer?
    You see my problem, so I am asking anyone that would like to help me I need good quality pictures of stock bikes of every year of the XS11. Some years are pretty easy others have been harder. If you want to contribute you can e-mail them to me at mcmotohistory@gmail.com Really looking for all years but a clean stock Venturer has been really hard to find, so send those pics and I post the whole thing back to this website when I'm done.
    81H Venturer
    • 724
    Mns
    A very noticeable difference in the midnights:
    The 80 LG has wheels with straight spokes.
    The 81 LH has wheels with curved/swirly spokes.
    • mcmotohistory
      • Aug 2015
      • 44
      I love your army bike. good work!
      81H Venturer
        • 724
        Thank You!
        • Wildkat
          XS Special Gurette
          • Apr 2004
          • 3416
          • Location, Location
          I think the black red, black blue and black gold are black paints with that particular color of metallic flake.
          81 SH Something Special
          79 SF MEAUQABEAUXS
          81SH Nor'eas tah (Old Red)
          80 LG Black Magic
          78 E Standard Practice
          James 3:17
          “Alis Volat Propriis”
          Yamaha XS 1100 Classic
          For those on FB
            • 8766
            With the exception of 80 Standard (80G) had solid rotors.
              • 2053
              Aluminum Grab Bar
              I think one of the most distinctive changes along the way was the cast aluminum grab bar on the Specials, starting in 1980 - in place of the chrome plated tubing in previous years.
                Hey McMoto,
                Not sure if you've found this section, but we have a few articles and photos of stock bikes in this part of the site. Well, actually this is just the Adverts/Brochures.
                But if you go to the menu bar at the top of the page, click on XS11INFO, it'll drop down, there you will find the Articles section as well.
                As was stated, the 81LH has swirly spoked wheels. There are other Subtle changes, the LH was the step before going to the XJ, and so they started incorporating some of the XJ changes into it....like the swirly spokes, the front brake calipers are different, and it has the linked system....left front caliper with the right rear, the front master cylinder only drives the right front caliper.
                There were considerable technical changes throughout the years of the XS11 to the XJ11. BTW, the XJ11 was made/sold 83-84 for Canada. Of course the XJ has a lot more electronics, the dash board, with more safety interlocks, clutch, sidestand, and gear position. It used OIL LEVEL and battery water level sensors instead of Oil Pressure sensor. Yamaha added 4 way emergency flashers in 80.
                The ignition system was changed in 81 to incorporate the Cent. Adv. curves into the TCI/black box. In 82, the Vac. Adv. curves were also incorporated/programmed into the TCI. The carbs were changed in 80 with larger vac. slides, plastic floats, different float valve needles/seats. The float vents were incorporated into the inlet bell instead of on the side of the carb body. The Pilot idle screw was smaller and placed inside a tunnel on the front top of the carb body.
                The Standards have fuel gauges and actual float/sender units. The Special use just a Thermistor sensor and low level idiot light. The standards have the boxier tanks, rectangular gauges, headlight, turn signals, recessed/flush gas cap. The front axle is just on the end of the forks, and the rear wheel is 17", the mufflers are straight and longer sticking out past the rear axle, but they had ROUND mirrors? Also lower more Universal shaped handlebars.
                The Specials have the tear drop tanks, raised cap, ROUND headlight, turn signals, gauges, but rectangular mirrors, front axle is mounted on front edge of slider, and has a 16" rear wheel, the mufflers slanted upwards a bit and were shorter. The handlebars were made more like ape hangers, affectionately called BUCKHORNS, and so the front MC is more slanted to function at that angle vs. the standards.
                • vedgar
                  • 311
                  • Clarkston, Michigan
                  79 specials.
                  I have both 79 Special colors. Carmine Red is one color (no metalic) . The other color is Black Gold ( has a very fine gold speckle in the paint. These are one year only colors also.
                  79 1100 SF Carmine Red stock
                  85 Honda v65 Magna
                  • robbo
                    • 106
                    • Aldershot. UK
                    XS1100 history link
                    Hey mcmoto. Looking forward to viewing the video. Here is a link to model history on our UK site. Hope it helps
                    Rob
                    Rob
                    XS Eleven SF
                    Could this be the finest Triumph Bonneville ever built ?
                    (Cycle January 1979)
                      • 7862
                      1980 XS1100LG
                      1981 XS1100LH
                      1980 XS1100G with tour pack
                      New ruby red
                      1979 XS1100F Majenta Red
                      XS1100SF Carmine Red
                      XS1100SF Black gold was black with tiny gold flecks in the paint.
                      XS1100SG Black red was black with tiny red flecks in the paint.
                      XS1100SH Black blue was black with tiny blue flecks in the paint.
                      XS1100SH
                      1978 XS1100E Macho Maroon
                      1980 XS1100SG New Ruby Red
                      If you want to see these things up close and in one place, you need to come to XS Southeast in September.
                      • vedgar
                        • 311
                        photo op
                        Thanks for the pic of my 79 carmine red SF Marty. Looks even better now with a new chrome grab bar.
                        Vance (vedgar)
                        85 Honda v65 Magna
                        • mcmotohistory
                          • Aug 2015
                          • 44
                          Pics
                          Thanks for all the info Jet
                          81H Venturer
                          • TomB
                            • Aug 2006
                            • 967
                            • Cumbria, UK
                            Are you interested in ALL XS1100 history or just US market?
                            Tom
