Noob engine help
  • AggiesaurusRex
    • Apr 2016
    • 57
    • Orlando, FL.
    #46
    I have the Acewell Coils, so I don't think I have a ballast resistor?
    80G
      Why ask?......check for yourself.
        hi fellas,
        I'm all ready to rumble but no spark. Zip. Nada.
        Its a harness from basically from scratch, it had to be done, I followed the manual and used what I could of the old harness to build to what I have now. My starter is still non-functioning but I'm able to use the kicker.
        When I test power to coils I'm only getting 3V??? Where do I start?
        Just saw this........start at beginning of electrical.....need 12-12.5v to coils.....battt. voltage would be a good start.
          No offense intended, but you SERIOUSLY need to learn this stuff as you go, just like the rest of us knowledgable folks. That way you can become of help for others here. I'm here to be of help, not lead someone around by the hand.
          • AggiesaurusRex
            • Apr 2016
            • 57
            • Orlando, FL.
            #50
            I'm trying to learn as I go... Sorting out electrical issues is immensely easier if someone with experience can lead you to water. The whole point of this forum is to get help. If you aren't here to help that's fine, get off my post, you don't have to comment. Someone who doesn't mind teaching and sharing their knowledge will help.
            80G
              #51
              If your voltage is below something like 10.3 volts (?) the black box will make no spark, even if you try to kick it.
                ....already initially did.....post #48. Try not to be so vague as to what you have already done or tried. Makes it easier for others to offer CORRECT help. Also, bunch of links here on site provided for most all issues one may have questions about.
                  #53
                  Scott/3Phase may still be busy visiting his father and/or nursing his XJ back home from XSSE, so that's why he may have not seen/answered/replied yet.
                  Like Motoman said, you will want to start at the battery. Then go to the fuseblock and check both sides for the ignition circuit. Don't forget the emergency cut of switch at the handlebar IF you still have it wired into the harness. Then at the TCI, there's a diagram somewhere showing the pinout for the TCI so you know which wire to check, but with you customizing the harness, it may be difficult to identify which wire is which.
                  If you are running ACCEL coils, AND they are the 3.0 ohm type then you should have removed/bypassed the ballast resistor, this way the coils can feed off of 12V ALL of the time. Like Skids said, the coils and TCI both need about at least 10.5V or more to be able to function.
                  • AggiesaurusRex
                    • Apr 2016
                    • 57
                    • Orlando, FL.
                    #54
                    Yep, ballast is gone.
                    My Red/Yellow is 0.02 after switching the key on, with the starter held it climbs to 8V.
                    My bottom Red/White (on bottom pin in TCI) which leads to my pickup coils reads 11.2, if I press the starter it dives down to 8 or 5.
                    My top Red/White (top pin) which leads to coils reads 0.1, if I press the starter and hold this jumps to 8V.
                    Anytime I press the starter I can here the solenoid click as it should. I've cleaned all grounds and ground connections. I also tested my voltage across my fuse box. I have 12.5 into in, 12.5 out to the key, 11.6 back in (this is a three-way branch, and 11.6 back through the other side. What's eating my voltage? When testing the Orange/Grey/White and Red only reads 2V.
                    Is there other things I should start to check? Help you genius gurus!
                    80G
                      STOP/Run switch completes circuit. Remove, take apart and clean contacts and cruddy connections. Notorious location for voltage drop as is its plug-in located top right of frame under fuel tank.
                      • AggiesaurusRex
                        • Apr 2016
                        • 57
                        • Orlando, FL.
                        #56
                        Motoman that's not the problem as I have 12V at that connection.
                        As I understand that red/white powers into the TCI box, my white/red, grey, and orange have basically no voltage among them.
                        80G
                          • 7842
                          White/red should be power to the coils. IF no power, check the kill switch.
                          • AggiesaurusRex
                            • Apr 2016
                            • 57
                            • Orlando, FL.
                            #58
                            Unfortunately or fortunately, depending on how you look at it, the killswitch is fine, I have power through it and the button functions fine, shuts of power when it should, and when on it's not a huge drop. Its 100% not the killswitch, not the red/white that's the problem. But after the killswitch I have no power. :/
                            80G
                              • 7842
                              Check the tip over switch. It's under the tank. If it froze in the "open" position, no power.
                              • AggiesaurusRex
                                • Apr 2016
                                • 57
                                • Orlando, FL.
                                #60
                                Unfortunately that's not it either. Tip over switch was removed by previous owner, deleted completely from the wiring.
                                80G
