Oil filter bolt NOT budging...
  • ERM83
    • Apr 2016
    • 314
    • Lehigh Valley, PA
    I can't even remotely get this thing loose.
    I didn't twist it like a crazy person last time I changed the filter. This is weird. So far, I've broken two ratchets, and two adapters trying to get this thing off. Lately, EVERY FIX that I try to do to this bike SHOULD take half an hour / an hour, and then I end up spending all freakin' day on it.
    Any tricks to this?? Already tried penetrating spray (AND letting it sit). Not wanting to use a 12-point wrench, for obvious reasons.
    80' XS1100 SG "Dottie"
    79' SF carbs
    MAC 4-1
    K&N Pods
    Accel 3.0 coils
    Tarozzi fork brace
    TC fusebox
    Picture update soon
    http://i53.photobucket.com/albums/g4...psej6wqu9l.jpg
    79' XS1100 SF (parts, will be reborn)
    http://i53.photobucket.com/albums/g4...snfgpozqn.jpeg
  • dpotter58
    • Aug 2004
    • 1866
    • Southern Maryland
    Breaker bar
    1980 LG
    1981 LH
    • ERM83
      • Apr 2016
      • 314
      • Lehigh Valley, PA
      ahhhhh....disregard this post! I finally found some threads on here (google on my phone wasn't finding the threads for some reason?!), and I guess the best thing to do is...REPLACE IT. This is one of the ONLY qualms I have about the engineering of these bikes...why THE HELL would they make that hex a 12mm?!?!
      79' SF carbs
      MAC 4-1
      K&N Pods
      Accel 3.0 coils
      Tarozzi fork brace
      TC fusebox
      Picture update soon
      • ERM83
        • Apr 2016
        • 314
        • Lehigh Valley, PA
        Breaker bar
        yeah, absolutely! I actually am at my apt. and not the garage (thought this would be a quick deal), so I don't have my breaker. Was trying to get an immediate/convenient solution. I didn't have to use a breaker last time, though. And that was removing the bolt after 15 years of it sitting....
        79' SF carbs
        MAC 4-1
        K&N Pods
        Accel 3.0 coils
        Tarozzi fork brace
        TC fusebox
        Picture update soon
        • soccer4m
          • 694
          big vise grips
          Hi Erm,,,I have had luck with those type of bolts with a larger vise grip,,,get it so it clamps reeeealy snub after closing and tap with a hammer and pray. It will usually turn with the shock of the hammer,,,,last resort is to weld on a larger nut and then twist off..............Mike in Sun Diego
          mike
          1982 xj1100 maxim
          1981 venture bagger
          1999 Kawi Nomad 1500 greenie
          1959 wife
          • ERM83
            • Apr 2016
            • 314
            • Lehigh Valley, PA
            Thanks, mike! That's my next resort...I just went and got an adapter for my 1/2 inch-drive wrench, along with a 3/8 12mm socket...I think that'll do. I didn't have anything but a 1/4-drive 12mm handy, and I REALLY didn't think it would be this ridiculous getting this bolt loose! Hopefully one of these methods does the trick. I'm DEFINITELY getting a new bolt VERY soon. Not trying to go through this annoyance again!
            79' SF carbs
            MAC 4-1
            K&N Pods
            Accel 3.0 coils
            Tarozzi fork brace
            TC fusebox
            Picture update soon
              • 5073
              I would try a strap wrench on the filter cup. There is a little give, but there are ears on the flange that will stop complete rotation. It may help to rotate it just the degree or so that it will go, back and forth. I would try the penetrating oil at the bolt flange and let it sit over night, and then clean the bolt head and apply valve cutting compound for grip with the hardened 6-point socket.
                • 8930
                Well that is your problem right there.
                • justinc1081
                  • Apr 2013
                  • 61
                  • Springfield, MO
                  First oil change for mine involved an easy out and a new oil filter bolt
                  With new bolt oil changes are easy as cake
                  80 SG
                    .....to keep those so inclined from over tightening them.
                      • 7832
                      Why would ANYONE try to remove a 12mm with a 1/4" drive!?!?!? Sorry, but this is a case of just trying to use the WRONG TOOL FOR THE JOB! Anything on the engine of an XS should be a 3/8" drive!
                      • Ken Talbot
                        • 4251
                        • Revelstoke, BC
                        Get it off with a 3/8 drive 12mm socket in an impact driver (hammer type, not air). Then grind down the 12mm head a bit more and weld on an 18MM nut.
                        Ken Talbot
                          Wow!.........has been ages since any posting from ya' Ken.
                          • ERM83
                            • Apr 2016
                            • 314
                            • Lehigh Valley, PA
                            It was all I had at the time...I didn't think it honestly would break. From a pretty sturdy tool set.
                            I got an adapter, and got it off. The bolt looks great; all the components are there. About to go cycle the oil around (it was WAY too cold to last night). All is well! Thank you!
                            79' SF carbs
                            MAC 4-1
                            K&N Pods
                            Accel 3.0 coils
                            Tarozzi fork brace
                            TC fusebox
                            Picture update soon
                            • speedlimit85
                              • Jan 2017
                              • 454
                              • Gainesville, Fl.
                              Glad you finally got it.
                              I changed my oil and replaced filter bolt today. When well. I am in an easier climate, and rode with a T- shirt.
                              80 G
