Gas tank repair
  • mschor
    • Jan 2017
    • 183
    • West Palm Beach, FL.
    Gas tank repair
    81 Special, 20 years in a garage. It's mostly clean, but behind one of the Yamaha signs on the tank it tired through. I cut out the rust. Is this repairable? Was thinking of JB welding a piece of metal over it and then fiberglassing over that so the fiberglass is not in constant contact with fuel. Sound like a worthwhile fix? Local welder said he'd probably warp the tank welding it.
    81 Special
  • mschor
    • Jan 2017
    • 183
    How to post a pic?
    81 Special
      • 8061
      Host the pic someplace else then click image icon
      Paste the address of the image there.
      • DavePlum
        • Nov 2009
        • 71
        • Longview,Tx
        I have no idea if it's now repairable now. You would have been much better off asking that question before cutting into the tank but it's possible you discovered this site after the fact? There are a couple methods used to remove rust from the inside of a tank. A radiator shop can clean and seal it but you'll need new paint after they're done with it and that process is not cheap. Many people on this site have used electrolysis, apple cider vinegar, or a combo of the two to remove the rust. If you do a search you'll find these methods discussed in depth.
        If your bike sat for 20 years the fuel tank might be the least of your problems.
        Good luck.
        • mschor
          • Jan 2017
          • 183
          I cleaned and coated the inside of the tank. I cut it out because it was still leaking after. Metal was paper thin there. What if anything to do now is the question.
          81 Special
          • mschor
            • Jan 2017
            • 183
            Yeah there's a lot more I'm working on as well but this is my last step before trying to start it up
            81 Special
            • soccer4m
              • 694
              Get another tank for safety
              Howdy,,,,I would highly recommend getting another tank, before we see you above a leaking one,,,,on flames going down the street. If its gone in one area, all it takes is another pinhole opening up and gas catching on fire to ruin your bike, and life. It would probably save you the same money and a lot more time trying to save a bad tank,,,,,lots of them available if you have a mc parts yard or ebay or craigslist, or try the parts guy in the parts section, andreas, very solid supplier for a lot of us..........your choice, but leaky tank is a lot of effort to restore,,,,,,good luck and hope your xs can give you a lot of fun riding....Mike in Sun Diego
              mike
              1982 xj1100 maxim
              1981 venture bagger
              1999 Kawi Nomad 1500 greenie
              1959 wife
                Hey there,
                Good advice from Mike. However, if you're wanting to try to repair, do NOT use JB Weld, it is not fuel proof, and actually breaks down with long exposure to fuel/ethanol!
                Others have sealed small holes and such with plumber solder or such, not as hot and as hard to do as welding. Then after fixing hole/plate/patch, then would suggest reapplying the tank sealant to the inside at least in the repair area. YMMV!
                  • 9981
                  Keep an eye on ebay, I've gotten them for as little as $30 in good shape.
                  http://www.ebay.com/sch/i.html?_from...100+tank&rt=nc
                  • ERM83
                    • Apr 2016
                    • 314
                    • Lehigh Valley, PA
                    hey, there's a couple of H's for sale around here...check louisville KY's craigslist. I've been looking stuff up on this board and haven't seen in the last day if they're still available on there (i'm on C.L. EVERY DAY...looking for a good deal on an SE/SF engine), but I KNOW one was a "project", and the tank was in really good shape....
                    If you can't find one close to you, just PM me, and I'll snag you one from here. We're lucky to have a couple of low-key shops, and salvage yards that have vintage bike parts here! There's a bunch of XS stuff as well...most people here that are into older bikes go Honda or Harley.
                    Eric M
                    80' XS1100 SG "Dottie"
                    79' SF carbs
                    MAC 4-1
                    K&N Pods
                    Accel 3.0 coils
                    Tarozzi fork brace
                    TC fusebox
                    Picture update soon
                    http://i53.photobucket.com/albums/g4...psej6wqu9l.jpg
                    79' XS1100 SF (parts, will be reborn)
                    http://i53.photobucket.com/albums/g4...snfgpozqn.jpeg
