Can someone tell me if these coils are dead?
  • Fields11789
    • Oct 2016
    • 40
    • Perth, Western Australia
    Ive been having no end of trouble tuning the carbs. I had it tuned on a dyno and when i picked it up it ran great. There were some jetting issues which need to be ironed out but perhaps thats to do with my possible electrickery and valve clearance problem.
    Then after about 20 mins of riding it ran like absolute garbage. loud back firing popping on acceleration rough idle which wont wants to stall out without a blip of the throttle. Missing and just generally very poorly behaved.
    I have had a good tug on the pickup wires and cant find a stretchy one.
    In the past i have been noticing that cylinder 1 wasn't heating up at all. I swapped the spark plugs around between 1 and 4 and then fired her up and cylinder 1 started heating up again without any effect to cylinder 4 .
    Then Cylinder 1 started going cold again. I chopped about 10mm of the lead and re installed which made some difference. Heated up but not as much as the other cylinders.
    I can swap the plugs over as i don't have enough length on the 2 and 3 wires.
    When the bike is running i can pull the plug cap off cylinder 1 and it has no effect at all on the RPM. however cylinder 4 (same coil) drops the idle a fair bit. 2 and 3 will stall the bike if pulled off.
    Compression is pretty good across all 4.
    150-140-140-150
    I must say that my valve shims need doing as some of my exhaust clearances are a bit tight.
    In 1 .005 2 .007 3 .006 4 .007
    Ex 1 .007 2 .005 3 .006 4 .009
    I read in the tech tips tips about testing the primary and secondary wires which i did.
    The primary wires were 3.8ohm and the secondary, well i dont know how to describe it (im not an electrickery expert).
    I had turn the meter up to 2m to get a reading on them, as the photos show.
    Im pretty keen to sort this out,
    1982 XS1100RH
    1982 KLX250B
  • Fields11789
    • Oct 2016
    • 40
    I took the coils out and tested the secondary without plugs. Big difference. (is that how i should have done it in the first instance?)
    I think maybe the 1-4 coil is kaput, yes?
    The 2-3 coil kinda came up around what the tech tip thread said it would.
    1982 XS1100RH
    1982 KLX250B
      If the secondary 1&4 coil really does have 1.2 million Ohms of resistance then it's dead.
      Does the resistance change when you pull and bend the high tension wires like there's a break or someone pulled them loose from the coil trying to see if the wire can be changed?
      • Fields11789
        • Oct 2016
        • 40
        No change in resistance. It fluctuates a small amount (between 1.295~1.285 but i think its due to me jiggling the probe.
        1982 XS1100RH
        1982 KLX250B
          It's dead. It's not just pining for a Ford, it's an ex helix.
          • Fields11789
            • Oct 2016
            • 40
            Thanks 3phase, Took me a google search to get your reference to ford an helix.
            Looks like the Dyna coil upgrade is going to happen. To be honest I was kinda hoping it would work out this way
            1982 XS1100RH
            1982 KLX250B
