Headlight ear removal
  • sethhope
    • May 2016
    • 226
    • Springfield, MO
    So I have this really ghetto fairing that the PO fitted to my xs. Only problem, they never finished and I still have the headlight ears attached to my forks. I read that I have to pull the front wheel and slide the forks down to remove them?
    I searched the clymer and the procedure has me a little worried... I've never worked on the front end of a bike before, or anything even similar.
    My question to all you gurus,
    Is it really a big job? Can it be done in a few hours? And should I be worried about doing it myself?
    I just have the thought in the back of my mind that ill screw up the front end and wreck the bike a mile down the road...
    1979 XS1100F "Roxy" (my first bike ) - '91 Suzuki GSX1100 Fairing, BMW bags, Cheap ABS Trunk, aftermarket cruiser seat, MAC 4-2 exhaust, Heavy Duty folding kickstart, XS11 Special signals and gauges, Blade Fuse Conversion, Dynacoil Greens w/ ballast bypass, SS brake lines
  • Eastcoaster
    • Jan 2012
    • 508
    • oceancity NJ
    Seth
    IMO I would leave them on there My Venturer came from the factory with the ears on the full dressed bike they are folded in and tied together Most important the factory had a bag over the connections Make sure you have the connections protected from the weather
    82 XJ1100J
    81 Venturer
    • sethhope
      • May 2016
      • 226
      • Springfield, MO
      Originally posted by Eastcoaster
      Seth
      I'll see what I can do with tying them in. Theres supposed to be a mount right through the front forks for my fairing though and it may interfere
        • 7830
        sounds like a Pacifico fairing. The mount DOES go to two 8mm weldnuts at the front of the neck. If so, yes, remove the headlight ears, or twist them both towards the center and put a zip tie to keep them out of the way.
        To pull them,
        1. loosen the top center bolt on the triple tree
        2. loosen the two clamp bolts on the top triple tree, and using the handlebars work it off the center. If you tip it towards the front, it should clear.
        3. pull the headlight ears
        4. put the top triple tree back on, tighten the center nut first and then the clamp bolts.
        This is from memory, and a while ago so I'm NOT saying it's 100%, but it should be close.
        IF the bottom of the headlight ears DO go on both sides of the lower tree, just loosen the 4 clamp bolts on it while the upper is off. YOU MUST HAVE A JACK UNDER THE FRONT FRAME TO KEEP THE BIKE UPRIGHT!
        • puskrat
          • Jun 2015
          • 312
          • Peoria IL
          Seth
          THIS
          My fairing is off (that ghetto unit may be the factory original) and the "ears" are surrounded by a bundle of wires and a bag.
          "Venturered" 80 XS1100G - "DoraMax" getting sort of resto/destro ed.
          Yeah it's a pretty blue, but just because you're old is no excuse to buy a bagger. Fortunately I have wrenches.
