cam installation procedure
  • Ronajon
    • Aug 2016
    • 7
    • Apeldoorn, The Netherlands
    what is the correct procedure for installing the cams and camchain.
    inlet first or exhaust cams first ?
    1979 Yamaha XS1100 Touring Martini
    • 3372
    Note: I have not done XS1100 cams however to my knowledge this should work for any set up to my knowledge. Done cams on a couple other bikes and it works fine. And I have not installed a cam chain. The chain has always been in place on the bikes. However this is how I get the cams in trouble-free.
    The cam chain tensioner is obviously upfront. Therefore the tight side is on the back where the chain comes up to go over the intake cam.
    First, timing mark where it needs to be. Next is to take out the slack on the tight side, set the (intake) cam properly on the tight side, keep the chain taut as I set the other (exhaust) cam properly in place then installing the tensioner, letting the tensioner pick up the slack on the "loose" side. Take your time and it should go fine.
    Someone else chime in if that is not an acceptable method to recommend.
    2001 ZRX 1200
    1982 Seca 750
    1983 Nighthawk 550
      • 4015
      NOTE: I HAVE done cams on the XS1100, and this was how I did it: I read the service manual! Like, not trying to be a smart-ass, but coming from a guy that has bent valves doing this procedure, then successfully done the procedure, it's imperative to get a Clymer manual. Step-by-step it takes you through, including torque specs on cam caps, etc.
      There are many write-ups on here regarding timing, cams, etc. I read them all, rushed, and still bent my valves. Second time around, I read the manual and it went smooth.
        • 3372
        Nice one! My question would be in principle, how much different is the service manual than what I shared? I totally agree and I do have the factory service manual outside in the cold garage and I'm not going to pull it out right now. :-)
        2001 ZRX 1200
        1982 Seca 750
        1983 Nighthawk 550
        • Ronajon
          • Aug 2016
          • 7
          Thx, what do the manuals say?
            Hi Ronajon,
            A choice of Manual here;
            Right side of page.
            I suggest you down load the manual and print the section about the cam installation. Saves getting grease all over your computer
            Read it then re-read it then take it slow checking your steps against the manual.
            The valves in the XS are extremely delicate. Better safe than sorry.
              • 4015
              I have no-doubt your advice is spot-on Bonz. But, when I see someone ask such a generalized question that involves the most critical aspect to the bike "timing", all I can do is think of my own experience and cringe, thinking what may happen to others, which we see too often on here.
              • sethhope
                • May 2016
                • 226
                • Springfield, MO
                MAKE SURE YOU PAY ATTENTION TO THE MARK ON THE CAM SPROCKETS. It's not in the manual, but if youve heard of my recent plight, it causes lots of problems. One of the bolt holes has a mark on it that HAS to be up during timing.
                1979 XS1100F "Roxy" (my first bike ) - '91 Suzuki GSX1100 Fairing, BMW bags, Cheap ABS Trunk, aftermarket cruiser seat, MAC 4-2 exhaust, Heavy Duty folding kickstart, XS11 Special signals and gauges, Blade Fuse Conversion, Dynacoil Greens w/ ballast bypass, SS brake lines
                  • 4015
                  If you are referring to the cam boss dots aligning with cam cap arrows, it specifically states that in the Clymer manual in the following steps:
                  "18. Carefully rotate each cam slightly, with an
                  open end wrench, until the dot on the cam
                  aligns with the arrow (A, figure 40) on the
                  center bearing cap
                  29. Rotate the crankshank clockwise (Figure 43)
                  2 complete rotations and align the "T" mark
                  on the timing plate with the fixed pointer
                  (figure 35). Check the alignment of the dot on
                  both cams to the arrow on the center caps
                  (figure 46)."
                    • 4015
                    Note: The above is two different steps, and is separated by many different steps in-between. Buy or download the manual, and follow it.
                      • 4015
                      Oh, I think I know what you're referring to. I actually think this myth has been busted, and makes no difference in timing. But, nonetheless, best to follow what the pictures show.
                      • sethhope
                        • May 2016
                        • 226
                        • Springfield, MO
                        I check this myth the hard way and bent 4 exhaust valves a week ago...
                        • Eastcoaster
                          • Jan 2012
                          • 513
                          • oceancity NJ
                          Steve Nailed this one. Including sprocket position
                          82 XJ1100J
                          81 Venturer
                            • 4015
                            I understand how you're reading that Seth, and just for some good educational banter, I believe tgere was a thread where someone used a degree wheel to confirm whether it matters up or down, and it did not. As-long as the dots align when @ TDC, ur good to go.
                              Marks up or down on a cam sprocket isn't what bent your valves. Sorry to hear about that, but you need to figure out that ACTUAL reason so you don't repeat it.
