Steering Head Bearing Removal Tools?
    replied
    The reason for the bearings to be loose enough to fall side to side is any resistance will cause you to actually steer the front end to maintain your line which will cause lack of control by it being jerky (for lack of a better word).
    Sticky steering bearings cause constant accidental over steer and over correction.
    It will seem like a whole new bike with a smooth steering head.
    Leave a comment:
    replied
    Well, got the steering head bearings done today. Looking back at it now, I have confidence in doing it quicker and better the next time, which I will have to on my Triumph.
    I had a nice piece of stainless steel bar stock cut at a 45 degree cut, with a nice point, ready to catch the outer race. That was worthless!!! Could not catch the race. I ended-up cutting the upper & lower races with the dremel, then bashing them in-half with a sledge and that stainless flatstock (acting as a cold chisel).
    The bad news was cutting into the actual neck, but hopefully it did not hurt it too much. The other bit of bad news was the fact that the bearings I took out were tapered bearings. Not sure if the PO did not grease them properly or not, but the top bearing was kinda still still, and the bottom bearing was smooth. Not sure if it is the case, but not having the dust seal installed in the top may/may not allow for premature wear? I did note that using the dust seal in the top allows for too much gap between the top yoke and the steering neck. So, I had to take it back apart and remove the upper dust seal.
    I did not have a spanner with a 3/8" drive attachment point to be used in-conjuction with a torque wrench, so I used the spanner wrench to tighten the bottom locking nut just enough to allow the wheel to fall to either side (which I presumed to be too loose, but Greg said to follow this).
    The front-end is put back together. I left the fender off, as I have to take the front wheel back off to replace it with a new set of tires, despite the front still being good. I'll save it just in-case.
    Waiting on the machine shop to finish my cylinder bore/hone job, and I'll throw that back on.
    Leave a comment:
  • hamjam
    replied
    Originally posted by vedgar
    Gotta love the manual, says to use a wooden stick or dowel. What planet are they from ?
    yes an ironwood rod
    Leave a comment:
  • vedgar
    replied
    Wooden Dowel
    Leave a comment:
  • vedgar
    replied
    Steering bearings done
    Ian, If you have and questions, give me a call. 248 736 6222
    Leave a comment:
    replied
    Hey Ian,
    Not sure if you saw my Godzilla rebuild thread, but I posted a fair number of photos regarding my process of the steering head bearings removal I did?
    It starts at this post below.
    Leave a comment:
    replied
    Magic's is a cool shop! Already had the bearings. So, looks like dremel is the way to go. My boss is loaning me his Motion Pro bearing tool.
    Hi Ian,
    I am sure others will be interested to hear and see pictures of how that bearing puller works for you. I have heard that All Balls are not the longest lasting bearings but no personal experience. Be sure to work the grease into the bearings where it is needed, there is a tool for that too but the heel of your hand works too . But you already knew all that
    Leave a comment:
    replied
    Leave a comment:
  • vedgar
    replied
    steering
    as usual, the top was easy, the bottom is a bitch. I tried to modify all kinds of punches with no luck. I was trying to find another way instead of the dremel. OK, give up, back to the dremel ( almost out ), gotta go get another wheel for the dremel. Magic motorsports keeps the correct all balls bearing in stock. Waterford, MI.
    Leave a comment:
    replied
    Roger that! Hopefully I can get into the corners of the on-ramps again with the change of tires and bearings.
    Leave a comment:
  • vedgar
    replied
    good luck Ian
    I am doing the bearing now and the tires too on old Red. Dremel is the way to go on the bottom. The rest is a cake walk. Like night and day after the change. I did my black 79 last spring. TAKE THE TANK OFF first.
    Leave a comment:
    replied
    Thanks for the pics Phil! The tires are being replaced, so it's a perfect time to do the bearings. Replacing the chain on the Triumph, along with different fog lights, so looks like it will be a busy day for me.
    Leave a comment:
    replied
    Hi Ian,
    It was a few years ago now but I recall the removal of teh Steering Head bearing. I was fortunate to have Rick and James operating on Addie.
    It helps to have a Hammer
    and
    BEER
    The front end has to come OFF
    Rick going in for the "kill"
    Thanks for the reminder of a good time with friends. It sure helps to have friends who know what they are doing.
    I was tasked with removing the part from the Triple tree , red hammer in middle of drawer, with cold chisel.
    Ricks instruction: I said Hit it not Tap it.
    Leave a comment:
    replied
    Originally posted by motoman
    Ian, another option if you don't have a Dremal tool with cut-off wheel to split the race, is if you have or have acess to an arc welder is to weld a bead around inside of bearing race. This shrinks the bearing race, and majority of time race will just fall out......BTDT more than once.
    I used to work at a mine and witnessed the removal of a very large bearing race with that method. You need to run that welding bead fairly quickly (don't stop to admire progress) to super heat the race.
    Leave a comment:
    replied
    Ian:
    I don't think any of those tools are necessary - they may or may not be useful.
    I think all you need is a long punch/drift and a big chisel....and a hammer....that's it.
    The top race came out easy for me. The bottom race gives folks the most trouble. Mine came out with a long punch and a little heat.
    If you can't get the bottom race out, folks cut it with a Dremel and it comes right out. It's inconsequential if you happen to score the neck a little bit.
    The other trouble spot for me (and the biggest) was getting the bottom bearing off of the tree. The trick for me was to have a big chisel to wedge it loose and walk it up.
    Putting it back together is no problem- just use the old races to drive the new ones, and find the right size pipe to drive the lower bearing.
    +1 here! Mine came out pretty well with just a punch and hammer from the neck. The tree gave me a bit of trouble so I just cut it off and was done with it. Don't worry about it.
    Leave a comment:
