Hi Guys,
I have seen that there are other posts relating to problems with turn signals however I can not find my problem.
My problem is this. When i push the turn signal left or right it clicks just once and does nothing. the lights do not flash, they do not go solid, they just do nothing. Not even the dash display lights flash. When i do press the turn signal, the dash lights dim when the flasher heats up.
So, i replaced all the globes with the standard 21w automotive bulbs. after reading i can not use them with the old flasher i swapped the flasher out for a standard 2 pin thermal flasher. No joy. So i went for a 2 pin electronic flasher, still nothing.
If i hold the signal switch left or right, the OEM flasher clicks very fast, the 2 pin generic thermal clicks very slowly and the 2 pin electronic flasher clicks at the speed indicators should.
Any ideas what would cause this?
