Barrel differences?
  • e30 gangsta
    • Mar 2016
    • 142
    • Lone tree, Colorado
    Barrel differences?
    Hey guys thinking about buy a spare set of barrels to send of to machining for my new engine. Small question though, are the barrels the same for all years of the xs? Thanks.
    80 XS1110 SG, RD400
    I want to say yes they are all the same. The pistons vary between the early and late motors only due to the dome top.
    • Fields11789
      • Oct 2016
      • 40
      • Perth, Western Australia
      I have a set of jugs from a 78 on my 81RH. Swapped straight over without any issues.
      Pistons fit in just right too. I saw no difference in the two I have.
      1982 XS1100RH
      1982 KLX250B
        Head itself is where differences are........combustion chamber volume and intake/exhaust valve sizes. Along with that, 78-79 have different cam profiles....duration, lift, overlap timing, etc..
        • mack
          • 2411
          • Ontario, Canada
          Get a
          bore gauge and measure them first. Tolerances are listed in the manuals. You need some life left in them because you should deglaze the walls with a honing ball or may have to rebore for a larger piston set. Sleves are available and if your significant other will let you use the oven, it a fairly quick change.
          mack
          79 XS 1100 SF Special
          HERMES
          original owner
          81 XS 1100 LH MNS
          SPICA
          78 XS 11E
          IOTA
          https://youtu.be/wB5Jfbp6SUc
          https://youtu.be/RaI3WYHSuWA
          Frankford, Ont, Canada
          613-398-6186
