Hi guys, I'm Andy from near Edinburgh, Scotland, UK. I should clarify that the epic fail involving the petcocks was my fault not the bike. I got my current 1980 XS1100G about a week ago after its import from the States. Although it's in real good shape, I dutifully set shout the fuel system as itclearly hasn't run for a long time. Taking the cover off one petcocks to find it totally blocked up with hard gunge which I set about cleaning out. It was at this point I had a flash of brilliance (Not!!!) and dismantled the other tap which was in the same state and which I also cleaned out. Unfortunately at this point I rembered that the taps are sided another I couldn't remember which bits were from which tap. What a dork!! Please can anyone overlook my stupidity and explain with words and/or pictures how to reassemble one of the petcocks assuming that the parts I will have left will make the other. Thanks
Andy
Andy
......along with CORRECTLY done float needle and seats.
........and carbs flooding over, with fuel running on hot exhaust. With bike being parked on closed in porch area, one member here had a gas fire that almost destroyed their home. I won't but could give you many scenarios from here on this site of bikes burning to the ground from not CORRECTLY repaired petcocks and float needles and seats. Not an area because of short funds to take a short cut
