Hey guys, Im a long time reader and recent member. I am in Aus an have been restoring a XS1100RH.
Looks like there is a wealth of knowledge on here and hopefully you guys an set me straight.
Let me start by saying, I am not a mechanic. I am a tinkerer at best. I'm not technically great but hands on and with the tools Im pretty competent.
Anyway...
Heres my issue, (this time)
I purchased this bike not running. Previous owner advised me he started it about 5 years ago.... It was in good shape however there was some rust inside the cylinder due to being left so long and never maintained.
New rings, gaskets, valve seals, thourough cleaning, 2nd gear fix (Gear showed wear and previous owner said it was having that issue) and just other general maintenance.
Tried to start her today. Misfiring out of the air filters, white smoke from exhaust as well. doesnt even sound close to turning over. there were a couple little splutters but not really note worthy... i checked the float levels and i had then set too high (got my measurements from a standard i think) floats are much closer to spec than before. same issue.
Any ideas? could the timing cause this??
Any help would be great!!
Anyway...
(according to my Clymers should it be Coil1 4-1 Coil2 3-2? Seems odd. Im not used to 4 cylinder though.
. So in a way I was right
. I haven't started her up yet but I'm sure that will probably help! Its a bit late to be cranking on a big bike this where i live. Especially if she fires into life with the screaming demon exhaust!
