'81 Midnight Special carbs?
Paint
Ooops, missed the edit timeout, and should also have said that I had the forks re-chromed and painted the lowers, fitted new headstock bearings, re-greased the swingarm bearings and painted the swingarm.
Still needs a few things cosmetically but winter is about to arrive here so I've time do it.
Cheers RobRob
XS Eleven SF
Could this be the finest Triumph Bonneville ever built ?
(Cycle January 1979)Comment
Thanks for the tip, but pretty certain there isn't.
What I have found though is that there is a shim under each jet needle, is that right?
Quote:
Hi Alex. What paint did you use on the swinging arm and is it a good match for the rest of the frame?
Cheers Rob
Just some Hammerite Smooth Black and 8 coats of it.Comment
There is one washer for the jet needle in the slide assembly but just so we're all on the same page it's item #33 on the Yamaha online catalog:-
Yamaha Street Motorcycle Parts | CARBURETOR - XS1100LH - 1981
#33 3F7-14952-00-00 WASHER, PLATE (7Y2) $0.88 4 ea.
Cheers Rob
The ate-up, acid-damaged, swing arm from my XJ1100 has to be repainted and rolling on multiple layers of Rustoleum is how I'd planned to do it.-- Scott
โฌ
โฌComment
Cool! Was it rattlecan, brushed, rolled, or sprayed?
[/QUOTE]
Thanks for the info on that and it was a rattle can spray on paint. I find with Hammerite that the longer it's left to cure the harder it becomes and less likely to chip and crack. I've got a parasol stand in the back garden which is left out in all weathers, all year, which I sprayed with Hammerite Smooth about 5 years ago and it's still as good as the day I did it. The secret is try and do the spraying in warm conditions. Should also say it's Smooth Gloss Black.
That's messed up quote but I hope you get the gist.Comment
Those right-hammered quotes worked fine, no problem! Well, five years from now I'll be scratching my head and thinking, "I don't remember any of this!" but that'll be from senility, not quoting.
Some paints do get better with time. I had some patio chairs that shrugged at aircraft paint stripper (methyline chloride) and just sat there while it cooked off in the sun down to a sticky, water and UV-resistant shell.-- Scott
โฌ
โฌComment
After piddling about with this pig of a bike for weeks now, I think i'm on the home straight.
Under those plugs that I managed to remove were some unmarked pilot jets with no jet size stamped on them and they had eight bleed holes.
So I've bought some 42.5 size pilot jets and the ones with six bleed holes.
I'm fairly certain this has been holding me up after doing research on this forum.
The carbs also had 125 mains across all four which I've changed for 120's.
What's the reckoning on these changes?
Picture of the new and old pilot jets.
Hey FJ,
We can't tell much from the photos of the jets. The # of bleed holes is a bit of a red herring. We thought they were important with regards to how rich/lean the jets behaved, but that's not the case. Yamaha came up with a newer style of pilot jet that actually doesn't even have any side holes, they were first made for the XJ1100 carbs. However, they will work for XS11 carbs also....because the way the pilot jet tower/chamber is built...there is NO ...I repeat...NO venting air supply port feeding the tunnel that the pilot jet screws into. The Jet seals against the bottom of the tunnel with the cone shaped tip, and the threads, seal the other end IN the tunnel...and there is NO way any air gets to the SIDE of the jets, so the bleed holes are redundant. I cut several carb bodies completely in half thru the pilot jet/main jet towers, and it revealed that there were NO air ports in that area of the pilot jet towers. Also, George/GLOWEVA put in the no side holed pilots into his XS carbs, and they ran and tuned just fine just like the vented pilots.
What does cause problems is using OFF brand/Generic K&L jets which are sized and metered totally different than Genuine Mikuni jets. The K&L's run excessively rich and are why folks can't get them to tune/idle properly, get black plugs, etc.!
SO....regrettably you didn't say what BRAND of pilot jets you got, but if they weren't MIKUNI, then you may still have problems trying to get it tuned....UNTIL you get genuine mikuni jets.
T.C.T. C. Gresham
I've bought genuine Mikuni mains and pilot jets.
I've had a look down the tunnels with a light and magnifying glass and can't see any air ports. I used TourMax float needles but they are sealing good at 23mm float height.
I'm starting to give up with this pig.Comment
Hello there, long time no post.
I've tried searching but not found anything like. So anyway, I've bought this 4W1 '81 Midnight Special and it's come with these carbs that seem to have some of the jet orifices blocked by something.
Is this right or what? Also the main jets are 125 across all four.
Anybody shed any light on what's happened and what I need to do? Thanks in advance.
81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.Comment
Cheers Rob
Just some Hammerite Smooth Black and 8 coats of it.. Stock pilot jets ARE 42.5, and need to be left that way also.
Hey Leggman,
IF they are truly 81 carbs, then somebody put the rubber plugs in by mistake, because the pilots need to feed from the float bowl. So...check your carbs to be sure they are 81 series, and do NOT have the sharing tunnel between the main and pilot jet towers.
A PO may have swapped an earlier model of carbs on to your bike, it's happened before. You can run any year XS11 with any year of carbs, just have to have the carbs jetted for the year of carb, not the year of engine.
T.C.T. C. Gresham
