Hi Everyone,
My winterproject (as i explained in my introducing post) will not start.
It was not used in years, and durty , dusty. It was placed in a shed, wich was dry.
First things first:
The first day i pcked up this neglected bike, i cleaned the tank, checked the sparkplugs, en airfilter. I bought a new battery.
I tryed to start the bike, after a few times starting it came a little back to life. It ran on 3 cilinders, but i was happy. It did not kept running, and the carbs flooded. the next try it did not fire, but when i let the start button go, after a second there was a big bang.
Than i made the discision to clean the carbs. the effect was the same, only big bangs after starting, somtimes after a few seconds when i let the button go.
I checked the sparks. All 4 do spark. But when i turn on the ignition, randomly it sparks. (on 1and 4, or 2 and 3) It is the same when i turn of the ignition. When i start i do have spark on al 4. It looks it could be running.
I dont get it. Is it normal that when you turn on and off the ignition, you get sparks?
What could be the problem?
Thank you!
First things first:
Thank you!
