Replacing the missing NLA 5H0-14462-00-00 SEAL with the aftermarket HCP22413 from xj4ever.com.
Chacal calls it a 'puck' and it fits into the air box partition at roughly 10 or 11 o'clock as you look into the air filter housing. If the foam seal is missing then unfiltered air will be pulled from the snorkel, under and around the air filter and then into the upper chamber of the air box next to the #1 carburetor boot.
Ready?
Great Scott! That small foam seal in the air box partition is missing!
Put a microscopic drop of air filter oil on the seal and work it into the foam, then slowly push the new seal into the air box.
The upper end of the seal housing looks roughly the same as the lower end but without as much open space. The seal will stay in place and won't just go through into the upper half of the air box and get sucked into one of the carburetors.
Almost there....
There!
Check the seal when you check the air filter. You can use forceps or hemostats to work the seal out and clean it, then add fresh oil.
Ready?
Almost there....
There!
