BS34 carb problem
  • JMilliken
    • Jul 2016
    • 8
    • Brookhaven, Penn.
    BS34 carb problem
    One float pin is rusted solid, and one is repaired. Do i attempt to work with this rack, or buy another?
    79 SF; XJ700S
    • 5069
    Is the repair good? I guess you got the rusty pin out to notice the rust, no? Your call. Rust can probably be cleaned off and the pin reconditioned. If you can make it work, go with it.
      .....soak the carb bodies completely submersed in a pan of EvapoRust overnite.
      • JMilliken
        • Jul 2016
        • 8
        • Brookhaven, Penn.
        The repair is good. The rust is pretty bad. I will soak it and give it a go. Nothing to lose, right?
        79 SF; XJ700S
          .......cept time.....kina like watchin' paint dry.
