Float height in reality is the main control of rich or lean when you come on the throttle in big handfuls.
I'm not going to budge on that one because I developed a full carb set up using ZZR1200/ZX11 40mm downdraft carbs on a side draft head for my ZRX 1200 and higher fuel level made it rich on the initial throttle application and lower fuel level leaned it out. Going around corners with too high of a float height which equates to low fuel level would starve the engine and had a lean hit when accelerating at more than a smooth roll on.
Lower the floats and raise the fuel level and it would bog rich. Sorry, I know what I'm talking about on this one.
