Choke problems
  • b2b
    • Jun 2015
    • 10
    • Chandler AZ
    Choke problems
    Hello everyone. I have 2 carbs that choke is stuck. I have removed nut and spring. How do I get it to release?
    Thanks Paul
    79 F
    • 7818
    You need to remove the set screw on the metal tang that catches the choke/enricher rod. Get a screw driver that fits it exactly, as there is locktight on it from the factory, and they are easy to strip. You then remove the rod, watching for the springs and 1/8" BB on the #1 & #3 carbs.
    • b2b
      • Jun 2015
      • 10
      • Chandler AZ
      Its the metal choke rod at carb 4. Choke rod at carb 3 released. Rick called me back and said to use a penetrating oil to get it to release.
      79 F
      • red bandit
        • 970
        • central michigan
        Are you sure it's the rod and not the #4 brass choke plunger that's stuck?
        79 SF parts bike.
        • b2b
          • Jun 2015
          • 10
          • Chandler AZ
          Red that is what it was. I didnt explain it right. I got it to break loose sprayed a little carb cleaner and it seems to be moving as it should. Hopefully going for a ride tomorrow.
          79 F
