Should I use 75-140 or 85-140?
Gear oil
Gear oil
XS1100SG "Lucy Ferr" - Build project. Biltwell Tracker bars, octy delete, rerouted breather hose, mini turn signals, bar end mirrors, TC's fuse block, TKAT fork brace. No fairings. No windscreen. No hard bags. More to come...eventually...Tags: None -
Marco
1979 Honda CBX
2002 Kawasaki ZRX1200R
WE MISS YOU, DON -
Those expensive name brands are no better than Walmart store brand..... just saying.Greg
The list changes.Comment
Marco
1979 Honda CBX
WE MISS YOU, DONComment
Awesome. Thanks guys. I'm honestly just gonna go with Amsoil. They're based and manufacture every product not even 10mi from the shop. I know countless people that trust their lubes more than any other brand.
Also, I got 4.4 and 1.4 ohms of resistance on my coils...both are a full ohm out of spec...thoughts?XS1100SG "Lucy Ferr" - Build project. Biltwell Tracker bars, octy delete, rerouted breather hose, mini turn signals, bar end mirrors, TC's fuse block, TKAT fork brace. No fairings. No windscreen. No hard bags. More to come...eventually...Comment
Also, I got 4.4 and 1.4 ohms of resistance on my coils...both are a full ohm out of spec...thoughts?79 FComment
Also, I got 4.4 and 1.4 ohms of resistance on my coils...both are a full ohm out of spec...thoughts?.
81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.Comment
The 81 model uses the 3 ohm coils with NO ballast resistor.
IF an SG, it should still have the 1.5 ohm coils and the 1.5 ohm ballast resistor, and so one coil is only 0.1 ohms off, The other would be ~3 ohms too high at 4.4 vs. 1.5.
And these are Primary wires...so the plug caps on or off won't matter with these readings. If you measure the Secondary windings, then you should remove the caps to determine if they are within specs of 15K ohms.
A final note, these OEM coils are 35+ years old, and were weak to begin with.
IF they are suspect, would suggest replacing with high output types, DynaTek or Accel, get the 3 ohm kind and bypass the ballast resistor, this way you can have 30+ KVolts firing energy ALL of the Time, makes starting much easier and eliminates low rpm ignition caused misses.
T.C.T. C. Gresham
Working on the SG. They still have the plastic connectors on and was using a ****ty multimeter. My field coil is running at 4.4 and stator coil is at 1.4 according to thatXS1100SG "Lucy Ferr" - Build project. Biltwell Tracker bars, octy delete, rerouted breather hose, mini turn signals, bar end mirrors, TC's fuse block, TKAT fork brace. No fairings. No windscreen. No hard bags. More to come...eventually...Comment
These coils still look absolutely perfect too. No oxidation whatsoever and the rubber gasket and wire housings are in perfect shape... I wonder if I just need to use a good multimeter and take off the connectorsXS1100SG "Lucy Ferr" - Build project. Biltwell Tracker bars, octy delete, rerouted breather hose, mini turn signals, bar end mirrors, TC's fuse block, TKAT fork brace. No fairings. No windscreen. No hard bags. More to come...eventually...Comment
Okay, when you talk about COILS, we usually assume you're talking about the SPARK PLUG COILS...that's the specs I was talking about, and what Dbshea and possibly even Motoman were thinking when they posted. OR also sometimes the timing cover PICKUP Coils.
NOW, it's clearer that you meant the FIELD COIL and the ALT Coil windings. I vaguely remember you talking about them in another thread???
T.C.T. C. Gresham
Like T.C. stated, maybe a bit of confusion. Eithr way, set multimeter to OHMS and check ohm reading across both poles of coil for ohm reading. Each coil, if still good should read 1.5ohm. Obviously, if they read that, they're stil good. .4 or less on reading,,,,,replace coils. Now, that is for ALL 78-80 XS 11's. 81 and XJ models use 3 0hm coils and no resister as stated by T.C.........same tolerance difference applies as with 1.5 ohm coils.81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.Comment
My Clymers is telling me that I should be getting 3.5 ohms on the field coil and 0.4 ohms on the stator coil...
I know it's not the definitive reference and has some discrepancies in it, but damn.XS1100SG "Lucy Ferr" - Build project. Biltwell Tracker bars, octy delete, rerouted breather hose, mini turn signals, bar end mirrors, TC's fuse block, TKAT fork brace. No fairings. No windscreen. No hard bags. More to come...eventually...Comment
Again, Motoman quoted an earlier reply of yours, and is STILL talking about the Ignition spark plug coils, not the Alt's Field coil and alt windings. Your specs for those appear to be correct, but having a properly calibrated meter is important in measuring that LOW of values. Try ZEROing the meter by touching the probe tips together, if you get 0 on the ohms scale, then good, but if you get some small value consistently, then you'll want to subtract that value of resistance from your actual measurements. Also, clean your meter probes, and the contacts of the coils, or if possible test the bare were just beyond the actual plug ends to ensure that you're not measuring corrosion in the crimp on connectors!
T.C.T. C. Gresham
Just measured the resistance of the multimeter across the probes and it's 0.9-1.0, so I'm only 0.1-0.2 out of spec!XS1100SG "Lucy Ferr" - Build project. Biltwell Tracker bars, octy delete, rerouted breather hose, mini turn signals, bar end mirrors, TC's fuse block, TKAT fork brace. No fairings. No windscreen. No hard bags. More to come...eventually...Comment
