I need a
    I need a
    Late model intake valve and 2 - .255 and 2 - .260 shims.
    HELP!!!!!!
  • Dbshea
    • Mar 2016
    • 133
    • Muskego, WI.
    HELP!!!!!!
    I have an entire head?
    79 F
      So do I, I just don't want to cannibalize it for one valve. Doc and I managed to somehow bend one valve on his just rebuilt head while we were adjusting the valves. I still can't figure how we did it.
        Did you have both cams in the head?? That's how I bent mine once, didn't realize that the intake and exhaust valves couldn't occupy the same space as the same time!
        I had both cams in, and rotated one which caused a valve to come out and hit one that was already sticking out. Didn't find out during my 2000 rebuild until after I had it all together and found 0 compression during a prestart test! Had to tear it back down to replace the valve.
        Sorry, all of my shims are 280+ in sizes.
          We had the new head installed and all the valves were WAY too tight. We were removing the cams to put thinner shims in to at least be able to get a measurement and Doc had removed the tensioner before we got the cam gears off. Had to turn the cams (crankshaft) to get to the gear bolts and the chain slipped before I realized the tensioner was out.
          At least it was only one.
          It sure doesn't take much to bend one. I never even felt any resistance.
          • mack
            • 2411
            • Ontario, Canada
            shims
            did you get a source for the shims yet Greg?
            mack
            79 XS 1100 SF Special
            HERMES
            original owner
            81 XS 1100 LH MNS
            SPICA
            78 XS 11E
            IOTA
            https://youtu.be/wB5Jfbp6SUc
            https://youtu.be/RaI3WYHSuWA
            Frankford, Ont, Canada
            613-398-6186
              not yet, no
                Greg,
                I have the valve if you still need it; not sure about the shims though, I can't find the film containers with the spare shims in them.
                  • 4015
                  I'll head to the shop and see what I have for shims. PM me your addy, and I'll drop what I have in the mailbox tom.
                    Originally posted by 3Phase
                    Greg,
                    Cool This bike has been in my garage for over a year, actually 2 garages. I had to move it when I moved. It's time for it to move.
                      • 4015
                      Got ur PM Greg.
                      • mack
                        • 2411
                        • Ontario, Canada
                        shims
                        I have four of each so i can spare some. PM me your address. As a side note, what numbers are you removing. I'm down on 150 & 145. Swap?
                        mack
                        HERMES
                        original owner
                        81 XS 1100 LH MNS
                        SPICA
                        78 XS 11E
                        IOTA
                        613-398-6186
                          I don't have ANY in the 100's I have tons of 265s, 275s, and 285s
                          • mack
                            • 2411
                            • Ontario, Canada
                            oops
                            Lol. Pm me your address and i'll have them in the mail tomorrow.
                            mack
                            HERMES
                            original owner
                            81 XS 1100 LH MNS
                            SPICA
                            78 XS 11E
                            IOTA
                            613-398-6186
                              • 4015
                              Hey Greg. Ur S.O.L. I think all the one's u need are in my engine. I have everything but those in triplicate.
