o rings
    o rings
    Anyone know a source for the tiny o rings on the idle mixture screws on the late carbs?
  • mack
    • 2411
    • Ontario, Canada
    O ring
    Yes Greg, go to a susuki dealer and order part # 13295-29900. They are rather dear at $5.49 can each.
    mack
    79 XS 1100 SF Special
    HERMES
    original owner
    81 XS 1100 LH MNS
    SPICA
    78 XS 11E
    IOTA
    https://youtu.be/wB5Jfbp6SUc
    https://youtu.be/RaI3WYHSuWA
    Frankford, Ont, Canada
    613-398-6186
      Thanks mack. found a set of 4 at XJ4Ever for $6.95
      Info@xj4ever.com is where to order if anyone's interested. Look up your part and part # in their catalog http://xj4ever.com/catalog/a-catalog-index.html and send an email requesting to order.
      Thanks to Stereomind.
        Yup........the Suzuki part numbers is what I used.
        Greg, make sure also, that the teeny thrust washers for the O-rings are still in place. If not, that is also a Suzuki part number. Let me know either way, as I have that Suzuki part number also.
        Those two parts are, and have been NA from mother Yammy for several yrs. now. Suzuki GS's used same carbs and those two part numbers are still available from Suzuki dealers........least were 5yrs. ago when I replaced those teeny O-rings and the missing teeny thrust washers.
          Ahhh.........got both part numbers for ya' Greg!
          teeny O-ring part number(4): 13295-29900
          teeny thrust washer part number(4): 13291-29900
            Yeah, Len at XJ4Ever asked if I had all the washers too, I have all of those.
            Lost one out of this SG project/sale bike I have. Found another screw and washer but I don't have any more O-rings.
            Len just sent me a confirmation email saying a new set will be in the mail in the morning.
            Why would 1 carb need the idle mixture screw turned WAYYYYY out to get it to idle right? I changed the screw, the pilot jet, checked float level (clear tube method Brant), even the carb body and it still wanted the screw way out. I assume that's why I lost it.
            What else could cause this?
              • 2104
              Maybe shaft seals or float level.
              Those O-rings are also available, in a pinch, at Harbor Freight.
              They sell a viton kit with assorted sizes and the smallest size is the schnizzle and you get like 8 or 10 pcs.
                Greg, what does a vacuum gauge show?
                Vacuum should be close to the same as the other three at the lowered RPM you use for setting the idle mixture screws.
                Pilot fuel and air jets and the circuit clean (I know you checked it already).
                Valve clearance(s).
                Prissy spark plug/wire/boot/resistor, try swapping the leads to check.
                A small vacuum leak.
                Bad throttle shaft seals letting air in around the shaft instead of fuel from the idle port.
                With the engine idle speed turned down, backing the mixture screw out until it clears the port should pretty much allow full flow from the idle circuit and the engine should start to run rich on that cylinder. If that's not happening, opening the screw further doesn't let any more idle mix go through the idle port but it will start letting air in around the threads and lean out the mixture as the o-ring and spring lose compression or the screw falls out....
                  Had the same scenario on one carb BA80.
                  Found it to be a split in one of the teeny O-rings, so, without taking any chances of any others not actually sealing like there supposed to, replaced all four. That totally solved any vacuum leak issues, and allowed mixture screw settings on all four within a screwdriver blade thickness of each other.
                  What it amounts to Greg, is there is a slight vacuum leak created with a faulty teeny o-ring, which forces the idle mixture setting screw to be WAY out to compensate for a previous lean mixture due to a slight vacuum leak from a faulty o-ring.
                    Valve clearance(s).
                    1; vacuum is the same as the others. Synced up good
                    2; carbs clean. As I said, I swapped out the carb body thinking there was an issue there.
                    3; swapped out the head because of a broken exhaust stud. Clearances good.
                    4; New plugs and resistor ends.....good blue spark.
                    5; First thing I checked for was a vacuum leak. Sprayed carb cleaner around intake boots and shaft seals. No difference. Boots in very good condition.
                    I ordered a new set of O-rings and got a couple of unbroken used ones to try from Stereomind when I was at his place a little bit ago.
                    If I cover the primary air jet just right I can get the idle to smooth out.
                    I've never had good luck with the late carbs for some reason. Unless, they are on someone ELSES bike.
                      ... If I cover the primary air jet just right I can get the idle to smooth out.
                      So too lean, you try just swapping mixture screws/o-rings? That should've been cleared up when you changed carb bodies around but WTH, until you get new ones try Brant's idea about shake-n-baked o-rings.
                      Edit: Or stick another set of carbs on and see if it clears up.
                      I know my carbs worked great until I got this totally stupid urge to check and reset the idle mixtures. Once I turned the mixture screws the o-rings weren't in their baked-in happy place any more and I eventually ended up buying some new ones from an industrial supply shop down in San Diego. I bought extras too so they're safely tucked away in a bag... somewhere.
                        I certainly know how that works. I put stuff up so I don't lose it then lose my memory. Can't win.
                          ....ya' got a PM.
                            I do? Guess I lost that too......
                              no,no.......not memory........PMs.
