well, broken cam cover bolt didn't want to come out...
  • ERM83
    • Apr 2016
    • 314
    • Lehigh Valley, PA
    WAY bummed out about this...if anyone remembers my post a bit back about my front cam-cover bolt snapping off into the head, I tried to get it out with a left-twist drill bit. It DID NOT want to come out. it was pretty much fused in there. now I have no freakin' idea what to do...can I re-tap it efficiently? has anyone done this? am I just screwed, and need to get a new head?? that was literally the LAST thing that I had to take care of before fully putting it back together. i'm irate, and literally lost sleep over it, haha. I just want it RUNNING!!
    80' XS1100 SG "Dottie"
    79' SF carbs
    MAC 4-1
    K&N Pods
    Accel 3.0 coils
    Tarozzi fork brace
    TC fusebox
    Picture update soon
    http://i53.photobucket.com/albums/g4...psej6wqu9l.jpg
    79' XS1100 SF (parts, will be reborn)
    http://i53.photobucket.com/albums/g4...snfgpozqn.jpeg
    Is the head on the bike?
    • ERM83
      • Apr 2016
      • 314
      • Lehigh Valley, PA
      nope...it's off. rebuilding from the cylinders up.
      79' SF carbs
      MAC 4-1
      K&N Pods
      Accel 3.0 coils
      Tarozzi fork brace
      TC fusebox
      Picture update soon
        If you drilled all the way through the bolt, get an easy out in it and put some heat to the aluminum around the bolt hole. Gently work it back and forth and see if you can get it moving.
        If all else fails take it to a machine shop since it's off already.
        • ERM83
          • Apr 2016
          • 314
          • Lehigh Valley, PA
          yeah, i'm going to have to take it to a shop...a few of the threads got jacked up, despite being almost dead center, and VERY careful while drilling. I tried head and an easy out, and still...nothing. soaked it with plenty of penetrating oil overnight, and still failed. ahhhh, this pisses me off to no end! I have other fixes that i'm going to do (T.C.'s fuse box, new turn signal assembly, etc), but the engine obviously needs to be first...one at a time. I have my carbs ready to go, but they need to be tuned...ONCE THE DAMN THING IS RUNNING!
          79' SF carbs
          MAC 4-1
          K&N Pods
          Accel 3.0 coils
          Tarozzi fork brace
          TC fusebox
          Picture update soon
            If you have a propane torch you might try some heat. I had an exhaust stud do me the same way but I kept heating it and letting it cool and repeating while working the stud and it finally gave up and came out.
            • aqqus
              • Jul 2016
              • 13
              • Sidney, NE.
              When I was in the navy we would have have aluminum cam lock fitting seize to iron pipe fittings. We would heat them up with a torch and sweat paraffin wax into the threads. After cooling we reheated the fitting and it would come off.
              81 S Venturer
              • Dbshea
                • Mar 2016
                • 133
                • Muskego, WI.
                Additionally, if you have the air duster in a can you could try getting the broken bolt hot and then hitting it with the can turned upside down to rapidly cool it. I'm assuming (since you've tried an easy out) that there is minimal original metal left in there. Rapid heat/cool should make it brittle enough to crack. Whack it with a small punch and use a pick to drudge out the remains. Then run a tap to try and salvage the threads?
                79 F
