Big Bore kit in a '79
  • sthomag
    • May 2009
    • 60
    Has anyone run the E-Bay big bore 1196cc kit in an early engine? I have a '79 that needs a rebore, but I don't want to risk bent valves or anything.
  • ViperRon
    • Feb 2011
    • 1062
    • Woodstock, VA
    The Big bore piston is the same as the 1980 pistons dome shaped I have heard of people putting 78-79 heads on the 80's engines to increase compression. I remember someone here doing the clay on the heads to measure the clearance so you may try searching threads for 78/79 heads on 1980/1981 model engines. I do remember the discussion was that if you change head keep the cams particular to that head. So if its the 78/79 head use the cams from a 78/79 and use the 80/81 cams in the 80/81 heads or you suffer performance issues.
    Rodan
    1980 G Silverbird
    1198 Overbore kit
    Grizzly 660 ACCT
    Barnett Clutch Springs
    R1 Clutch Fiber Plates
    122.5 Main Jets
    ACCT Mod
    Mac 4-2 Flare Tips
    Antivibe Bar ends
    Rear trunk add-on
