Thinning the "herd" and need some input
  • Dbshea
    • Mar 2016
    • 133
    • Muskego, WI.
    One year ago I had zero xs1100s. By chance I now have 7 and I've already scrapped one out. I won't get into the details but they are in varying states of repair. One 79 standard is my rider and isn't going anywhere. The other is a 79 special that needs small bits to be back on the road and will be staying in the family.
    Of the remaining hoard there are 2 79 specials that will ultimately need to join forces to make a solid runner. One frame is very clean and engine has good compression numbers/generally filth free so I have faith in it as a runner. The other frame is all there but obviously weathered. The engine does run but is ejecting an array of sparkling oil from the #4 exhaust port. I have deemed it DOA and won't be putting any effort into it. The frame is clean titled however, and my question is...is it worth trying to find a home for this titled frame? Parting bikes out is MUCH easier with a saw blade but if you cats think I should try and rehome the frame, I'll consider it.
    Next is a 78e. I haven't checked compression numbers on it, but other than the exhaust it seems to be unmolested (down the factory glass fuses). It too has not been weathered well, but is salvageable. There is a nasty dent in the tank however. I'm considering getting it running and riding (on the cheap) and handing it over to a good friend who will most likely modify it to his own taste (which may heavily stray from the original e). Am I doing a huge disservice to the lineage? I REALLY don't want to put the effort into getting it back into original condition...
    Next is a 79 standard that seems to be pretty well cared for save the ridiculous lighting and sirens affixed to it. You might ask "hey, get that 79 fixed up for your buddy and save the E". Well, you're logical but best friend pricing doesn't garner the pick of the litter and I feel like this standard can make a good clean rider for someone outside of my circle of friends.
    Lastly, I've got a venturer. Before your mind wanders to its indigo blue glory, with bags and fairings. It's not that. It's at best a ghost of its former self. Engine is long gone, as are all the plastics. The tank has been mangled. Ultimately it's saving grace is the vin and title. But, is it worth trying to find a home for that? Believe me when I say it is a LONG way from its days of glory.
    I'm not trying to make a mint on anything. I ask these questions NOT to find value in a monetary sense, but in the nostalgia of the line. Am I going to be breaking anyone's heart if I scrap a venturer frame, a beat to hell special, and turn a 78 e to the dogs? What would you guys do? I'd live to keep them all and putz with each of them in time but I don't have the time or money for such things.
    79 F
  • Rickrod3
    • Jun 2009
    • 721
    • Oakland, New Jersey
    What condition is the frame?
    650SF
    XS1100SG Project bike
    • Dbshea
      • Mar 2016
      • 133
      • Muskego, WI.
      Generally pretty good? There was a pretty gnarly leak at the front side of the engine judging by the 1/4" of grime on the down tubes. Everything looks straight, no obvious stress in the welds. The standard wear marks along the back bone/seat rails. The only obvious "damage" is the rear fender mounts nuts at the very end of the frame. Looks like they fell out and were replaced with a nut/bolt.
      79 F
      • Rickrod3
        • Jun 2009
        • 721
        Rather than scrap it id be interested. Could you post some pictures?
        650SF
          Hey Db,
          They are your bikes, you know what's salvageable and what's not. What's that old phrase, don't throw good money after bad!? As for the frames with titles, you can still part out the other parts, and IF someone comes up with the need to replace a frame, or they have an otherwise untitleable bike, they could get one of your frames, and do a transplant to be able to register /license their bike!?
          Glad you know what bike to donate to the potential bobber. We all know how hard and expensive it is to try to RESTORE one of these machines, and so nobody should fault you for not trying to save every bike!
          • Dbshea
            • Mar 2016
            • 133
            • Muskego, WI.
            Hey Db,
            That's the boggle TC. I know there are guys capable of breathing the appropriate life back into these things but I'm just not at that phase of life. I've got the 78 up on the lift, should be running tonight.
            Rick, once I clear some space out I'll try and get pictures of the 81. That one for sure won't get scrapped, I know they have a following and it would be sacrilegious to hack it up and dump somewhere.
            79 F
            • Dbshea
              • Mar 2016
              • 133
              • Muskego, WI.
              79 F
