1980 SG that will start and idle, but fouls plugs quickly when ridden. Background info on what has been done is in another post. Carbs coming off again for new jets and fuel level recheck because jets were stamped 110 (not marked as Mikuni though) and the valves were replaced with KL. Want to clear this voltage problem before I crank it back up.
While working to get proper voltage readings at the fuse box I found that the system drops well over a volt when key is turned on. Figured out that the tail light draws .2v which is way less than it is actually losing. After isolating circuits during troubleshooting I discovered the voltage drop does not occur when the 2 wire connector to the alternator/stator is unplugged and key is switched on. Also, the plug is warm to the touch after key is on for a spell and it arcs when separated. Test at plug is 3.5 ohms and the 4 wire plug is 2 ohms across and infinite to ground. Don't remember the exact charge rate at the battery while running, but it was above 15v and the bike hasn’t run long enough to flatten the new battery. The headlight is inop while running as well.
The voltage drop and warm to the touch plug indicates a problem somewhere in the alternator/stator system to me and maybe someone else has encountered symptoms like this while chasing the smoke?
