Yet another question on choosing right shims - re. valve adjustment
  • Andy_WI
    • Jun 2016
    • 34
    • Tomah, WI
    Hi. This is my first post here. Allow me briefly introduce myself - I am Andy and I recently got my first 1980 XS1100SG (vin# 3J6-003140). Seller said it was ridden last Summer and tabs are 2008, it appears to have 25K miles on the clock. I am in located in Midwest Wisconsin. I have big plans for my XS but for now I got confused with my shims as I am adjusting my valves at the moment based on crazy steve's Valve Adjustment Pictorial. I just downloaded manual from CatatonicBug's web site
    My measurments:
    Intake [1/2/3/4]: .000 / .004 / .003 / .0015
    Exhaust [1/2/3/4]: .006 / .004 / .007 / .006
    Shims that were installed:
    Intake [1/2/3/4]: 285 / 290 / 280 / 290
    Exhaust [1/2/3/4]: 265 / 255 / 275 / 275
    According to captjanes' post: referring to the manual on 1980 Midnight Special (XS1100SG) specs should be as follows:
    Intake: 0.004 - 0.006" (later specs)
    Exhaust: 0.008 - 0.010"
    I plan to source my shims via eBay and I am just got confused what sizes I'd need. I'd appreciate any explanation/clarification on this.
    I did see the chart
    Thanks
    1980 XS1100SG
    1991 HONDA CIVIC EF
    1998 DODGE RAM 1500
    My measurments:
    I did see the chart
    Thanks
    ..well, if ya' got a local Kawasaki or bike shop nearby, Kaway shims are same diameter.
    • Andy_WI
      • Jun 2016
      • 34
      • Tomah, WI
      Yes, I am aware of Kawi's shims and BMW's use the same 29mm dia shims. But what thickness do I need? That's what I am trying to figure out. I'd rather order stuff online then drive for hours and spend more on gas (my rusty truck is not so fuel efficient )
      1980 XS1100SG
      1991 HONDA CIVIC EF
      1998 DODGE RAM 1500
        • 1262
        • Peachtree City, Georgia.
        SNIP
        My measurments:
        Andy,
        Rather than go to E-Bay. You can buy individual shims from "JETSRUS.COM". They are aftermarket shims but brand new not used. You probably only need about 5 so they will ship them all at once for one small ship fee. Much better deal than anyone on evil-Bay.
        I'm no super expert here but let me try to help. I have a few XS11's and have done this adjustment several times.
        Your valves are obviously too tight. There is only one within spec and it's at the bottom end of the spec.
        You're gonna want to drop the sizes on them by one step each (that will PROBABLY do it on the exhaust and the two middle intakes). Looks like you can move a couple around (2.80mm over to the spot where the 2.85mm is that is too tight, etc.) and save a couple bucks. That #1 & #4 intake look like they will need to drop two sizes as they are SUPER tight. Personally, I'd buy a couple extra in sizes of the range you need if you can.
        You'll need to double-check them all again once the new shims are in.
        Hope that helps....
        KURT
        1982 - CBX1000 - Honda
        • Andy_WI
          • Jun 2016
          • 34
          • Tomah, WI
          Kurt, thanks for the reply and the link. I agree that I'd like to get couple extra shims as valve clearance check required every 5000mi (8000km) or 12 months. I wrote incorrectly intake and exhaust shims in my previou post. So here's what I've come up with:
          IN.specs: .006 -.15mm
          Intake:
          1: .000-.00mm | 265 -> replace with 255
          2: .004-.10mm | 255 -> replace with 250
          3: .003-.07mm | 275 -> replace with 270
          4. .0015-.03mm| 275 -> replace with 265
          EX.specs: .010 - .25mm
          Exhaust:
          1: .006-.15mm | 285 -> replace with 275
          2: .004-.10mm | 290 -> replace with 275
          3: .007-.17mm | 280 -> replace with 275
          4: .006-.15mm | 290 -> replace with 280
          Therefore based on this I'd need to purchase 250 x 1, 270 x 1, 275 x 1 and couple extras. I think I got it right
          1980 XS1100SG
          1991 HONDA CIVIC EF
          1998 DODGE RAM 1500
            • 4015
            Hey Andy- if you have the chart, it tells you what shims u need to replace them with.
            • HalfCentury
              • 408
              • Burlington NC
              After you replace, you measure again to see if you got it right.
              Be aware that you may need to drop more than you think. I had two that needed an additional step lower than what the chart would have you believe.
              It could be that I measured incorrectly initially.
              It helps to have a metric feeler gauge. They are $10 at NAPA.
              82 XJ1100 - sold
              2000 ZRX1100 - sold
              2003 FJR1300 - Silver rocket
                • 4015
                They have the 45 degree one's as-well, which are great for my Triumph.
                • Andy_WI
                  • Jun 2016
                  • 34
                  • Tomah, WI
                  Thank you for all feedback. I understand it's trial and error process. I have metric gauges and I will check my local (but it's still like 1 hour drive away from me) NAPA for shims but I might just go ahead and order shims online from jeturus.com. I will make sure I'll re-check clearance once everything is assembled back. I will report here
                  I picked up today Windjammer Vetter fairing and stock air box assembly
                  1980 XS1100SG
                  1991 HONDA CIVIC EF
                  1998 DODGE RAM 1500
                  • HalfCentury
                    • 408
                    • Burlington NC
                    NAPA does not have the shims. They have the metric feeler gauge.
                    82 XJ1100 - sold
                    2000 ZRX1100 - sold
                    • BillyRok
                      • Aug 2011
                      • 421
                      • Shortsville, NY.
                      You may find you need to drop 3 sizes on #1 intake so you would want another 250 on hand to be safe.
                      Billy
                      • Andy_WI
                        • Jun 2016
                        • 34
                        • Tomah, WI
                        HalfCentury - got it. Thanks for the clarification.
                        BillyRok - thanks for the suggestion. I will get an extra 250 then.
                        1980 XS1100SG
                        1991 HONDA CIVIC EF
                        1998 DODGE RAM 1500
                        • Andy_WI
                          • Jun 2016
                          • 34
                          • Tomah, WI
                          Update: I've installed new shims and checked everything twice and I had to re-install them again. I still need two more shims:
                          1 | 2 | 3 | 4
                          EX: .009 .010 .008 .013
                          275 275 275 265
                          IN: .006 .007 .006 .004
                          250 250 265 270
                          So I will replace I2 for 245, swap E4 for I4 and I'll need 275 for E4.
                          1980 XS1100SG
                          1991 HONDA CIVIC EF
                          1998 DODGE RAM 1500
                            Andy,
                            If they are a little LOOSE, that is OK. The shims tighten as they wear, so it just makes it noisy for a thousand miles or so. I would leave I2 as is if it was my bike, but that's me. I DO have an assortment of shims, so if you need a size PM me and we can mail back and forth. The "new" engines were tighter on the valve specs to keep the valve noise down, so 1 thou isn't a big deal.
                            • Andy_WI
                              • Jun 2016
                              • 34
                              • Tomah, WI
                              Ray, thanks for the info but this is sick perfectionism in action. It's been about one month and I still have not put my XS back on the road. I've ordered some shims online on Sunday night (eBay free shipping this time) and I really hope this weekend I can start riding. I am going to have some spare shims on hand now too.
                              1980 XS1100SG
                              1991 HONDA CIVIC EF
                              1998 DODGE RAM 1500
