Rebuild time?
  • Nubian
    • Apr 2011
    • 467
    • The Big East
    Rebuild time?
    Here are the results of a cold compression test on my XS1100H are they too low?
    D / W
    1) 110/125
    2) 90/110
    3) 110/115
    4) 90/95
    BAMN!
    '81 XS1100H "Brutus"
    • 8962
    Is this test with wide open throttle? Has the bike been sitting for a long period of time? How many miles on the engine?
    • Nubian
      • Apr 2011
      • 467
      • The Big East
      WOT? held start button for 4-5 kicks, about 1 year, 51K
      BAMN!
        • 8962
        Yes, you want to hold the throttle wide open so the engine can breathe, otherwise the carb throttle plates will be closed and you will get a low reading.
        • Nubian
          • Apr 2011
          • 467
          • The Big East
          D / W
          1) 110/125
          2) 90/110
          3) 110/115
          4) 90/95
          WOT results (will oil left over from last night's wet test affect results?)
          Dry
          1) 130
          2) 105
          3) 120
          4) 100
          BAMN!
            • 8962
            I bet if you run the bike some, the numbers will come up. Poor valve adjustment will give low readings too. Those readings aren't all that bad. 51K is nothing for these motors. Yes, if you added oil to the cylinders it may bring the numbers higher.
            • Nubian
              • Apr 2011
              • 467
              • The Big East
              Well it was running poorly last year and thought I had to do the carbs over, which I just did. having a hard time getting it running right. #1 as hot as others maybe a stuck float, will investigate and report back
              thank you
              BAMN!
              • Nubian
                • Apr 2011
                • 467
                • The Big East
                1 cylinder not firing righting is warm to touch not hot like the others. swapped writes with #4 same result. stuck float? 3 cylinder is suspect from looks of plug. Can't post pix
                compression test WOT engine hot
                1) 145
                2) 125
                3) 135
                4) 120
                BAMN!
                  • 8962
                  If the bike sat for 1 year with ethanol type fuel, the carbs are most likely gummed up. Compression numbers look fine.
                  • Nubian
                    • Apr 2011
                    • 467
                    • The Big East
                    The first thing i did was clean the carbs. Could #1 carb be running to rich is that why it's not as hot
                    BAMN!
                    • HalfCentury
                      • 408
                      • Burlington NC
                      Float heights. Check with clear tubing attached to drain holes.
                      Bowl enrichment circuit possibly clogged
                      82 XJ1100 - sold
                      96 Honda Magna 750 - Girlfriend's bike
                      2000 ZRX1100 - sold
                      2003 FJR1300 - Silver rocket
                        • 8962
                        Probably gonna have to go back in there and find out what's going on. Does the header heat up at higher RPM's? What does the #1 plug look like?
                        • Nubian
                          • Apr 2011
                          • 467
                          • The Big East
                          floats were set @ 21mm
                          is that enough (2mm) to cause my problems?
                          will set to 23 and report back
                          BAMN!
                            Yup.....21mm is to high a float setting. Actual reality is 1mm of float change equals 3mm of actual fuel level change. So, again, float setting your using allows for WAY to much fuel.....as is WAY rich. Fuel and fuel float level settings are actually done measuring float settings. Then, for 81 and XJ's, as per Yammy manual, actual fuel bowl levels are checked with bike idling, with a clear fuel hose slipped on bowl drain nipples and held up beside carb to see actual fuel level, which should be 3mm down from carb body casting.
                            Most importantly, running fuel levels in all four carbs need to be EXACTLY the same. Unfortunately, a static float level setting of 23mm is NOT going to leave all four fuel bowls the same fuel level.........so yep, you guessed it.....note fuel levels in all four and remove carb assembly and float bowls and make necessary float adjustments.
                            FWIW, running fuel levels of 3mm are approx. center of float bowl lock washers.
                            • Nubian
                              • Apr 2011
                              • 467
                              • The Big East
                              FSM-says 23mm is the height for floats
                              BAMN!
