XS1100 1978 Fuel Vacuum Pet Cocks leaking
  • Peter Brackett
    • Sep 2010
    • 9
    I have replaced the diaphragm and gaskets for both sides 3 or 4 times on this bike
    When I take the assembly apart and carefully check for rough or irregular area, can find none.
    I have tried storing it dry and leaving the fuel in to keep it wet
    But I still end up with slow leaks usually from under the pet cock
    And lots of complaints for the garage smelling like gas
    This time the fuel on one side of tank is free running into the right hand carbs
    and coming out into the breather
    I'm at the point of replacing the vacuum pet cock with just a simple on -off-reserve valve that is reliable
    Just checked Mack's Standard Petcock Alternative article- certainly one alternative
    Is this issue with fuel leaking a regular occurrence with 1978 XS1100's- very frustrating.
    Regards, Peter
    Regards, Peter
    .........other alternative....... may try stretching the internal springs just a bit before assembly.
    • red bandit
      • 970
      • central michigan
      If they are K&L kits that may be the problem.
      79 SF parts bike.
      • newc4
        • 643
        • Vienna VA
        I had one of mine leak once. Took it apart, cleaned it up. Remember putting emery cloth on glass and sanding down the face? Flexed the spring a bit and reassembled. Works great.
        Darrell
        78E
        80G project
        06FJR
          • 2096
          This thread may help
          http://xjbikes.com/forums/threads/re...-w-pics.25058/
