Cluster Lights?
  • SSthis79
    • May 2016
    • 17
    • Inglewood, CA.
    Cluster Lights?
    Hello all Ive been trying to start my bike for the first time in two years and have been running into some minor problems. Anyway I was wondering if anyone knows what lights on the cluster should come on when I put the key in the ignition and turn it? I only get my red oil light on, but goes away when I crank the engine.
    79 SF
    • 1262
    • Peachtree City, Georgia.
    SS,
    The lamps that illuminate the gauges, the neutral lamp (if in neutral), and oil lamp should come on when you turn on the key. The reason the oil lamp goes out is because you've built a little oil pressure when you cranked it. A few seconds after cranking, if the bike does not start, it will come back on.
    KURT
    1982 - CBX1000 - Honda
