float bowl
  • float bowl
    can i use a 650 float bowl on a 1100
    Resigned
    interchange
    is a 650 float bowl interchange with an 1100?
    Resigned
      I would think so as long as the year and style match.
      The only jetting in the 80-81 through the float bowl is the circuit for the choke
      cold starting jet.
      Now the earlier carbs would have the main and pilot jets in them. They would need to be the same as what was in there.
      But can't say 100% ?
      76 XS650 C ROADSTER
      80 XS650 G Special II
      https://ibb.co/album/icbGgF
      80 XS 1100 SG
      81 XS 1100LH/SH DARKHORSE
      https://tinyurl.com/k6nzvtw
      AKA; Don'e, UD, Unca Don'e
        The answer is definitely maybe. The late XS650's run with Mikuni BS34 carburetors, but I can assure you that they are not the same as what's installed on the XS1100.
          thanks
          im thinking of putting 81 bowls on my 80 carbs so i can check fuel level quickly
          Resigned
            Sorry, won't work.........has been thought of before.
              Sorry
              No it won't fit. Also the bowls are not all interchangeable between years of XS's. What year of carbs do you have. Basically there are three config's of carbs. 78/79 are referred to as early carbs. Then 1980 had a bastardized production line where the enrichment tube is slightly offset the in 81 they came out with a drain fitting in the bottom of the bowl.
              mack
              79 XS 1100 SF Special
              HERMES
              original owner
              81 XS 1100 LH MNS
              SPICA
              78 XS 11E
              IOTA
              https://youtu.be/wB5Jfbp6SUc
              https://youtu.be/RaI3WYHSuWA
              Frankford, Ont, Canada
              613-398-6186
