Torque wrench
  • dbbrian
    • May 2016
    • 596
    • Stratford, Ontario, Canada
    Torque wrench
    I couldn't find a new thread button under tools...
    In the past I have done all my wrenching without a torque wrench.
    I want to follow the specs on this bike.
    Is this adequate for use on the XS?
    What's it's range? You need to be sure what you get covers the torque range you will be using it in.
    • dbbrian
      • May 2016
      • 596
      good point.
      FEATURES
      Stanley FatMax 3/8-in Drive Torque Wrench offers a 20-250 in-lbs torque setting
      Perfect for use on lawnmowers, bikes and engine parts
      The go-to-tool when precise torque is needed
      Features an ergonomic rubberized handle
      Audible and Mechanical torque indicators
        Although an inch # torque wrench is nice for the smaller bolts, you will still need a foot # wrench for most bolts on our bikes.
        • dbbrian
          • May 2016
          • 596
          Thanks. I went and checked them out, took out of package - now I see.
          The ft / lb one is really long. I also looked at the oil drain bolt torque - 31 ft /lbs. so looks like I need that long one for job 1.
            Axle bolts are like 51 ft lbs, among others. I know the professional mechanics may roll their eyes, but I've had good luck with Harbor Freight torque wrenches at @ 10-20 bucks a piece depending on the sale. They get me closer in the ballpark than my non-calibrated "Gootentight" wrist does.
              Brian,
              Princess Auto has a 1/2 drive torque Wrench on sale this week.I think $20
              It will be fine for the higher torque requirements. Then watch their flyer for an Inch pound wrench ( I bet within 6 weeks )
              i suggest you change all the fluids...then you will know when it was last done. Depending on brand the o rings come with the filter.
              • dbbrian
                • May 2016
                • 596
                Thanks for the tip Phil. I'll pick one up for sure.
                and yes, I'll be changing the oil.
                • Prothec
                  • Jul 2007
                  • 587
                  • Fort Myers, FL
                  I rely on a 3/8" Harbor Freight torque wrench primarily and it works fine for me, YMMV. For the higher torque for the axles, etc, I use a 1/2" Craftsman beam torque wrench.
                  The HF torque wrenches are currently advertised at $21.99, but look around for coupons. Their ad in the latest July Motorcyclist magazine I get has a coupon for $11.99 for the same torque wrench, for example.
                  Edit: Nevermind, you're in Canada.
                  Website/Blog
                  • TADracer
                    • 1417
                    • Kenner, Louisiana USA
                    I have had adequate service from HF wrenches but for the 6mm cap screws that hold on a lot of things like valve cover, these are torqued to only 7.5 #/Ft. Have not had much trust in the HF wrenches for tightening these. I currently have a Craftsman in/# wrench and there is a distinct difference.
                    Having said all that, a long time ago a well known drag racer told me it is sometimes not so much how tight you put a pattern of bolts but it is how evenly you tighten them to the pattern. If you are a bit off but still get good bolt stretch then the bolt should hold. So a cheaper wrench is better than none at all.
                    Mike Giroir
                    79 XS-1100 Special
                      Incorrect........ correct torque is not 'bolt stretch' but thread seating.
                      • TADracer
                        • 1417
                        OK, we will go with that.
                        Mike Giroir
                        79 XS-1100 Special
                        • dbbrian
                          • May 2016
                          • 596
                          Got the Princess Auto one.
                          Thanks for the help!
                            Buy several of them in different torque ranges. I tested some of the cheap ones. All were dead on accurate in the middle of the scale. Take care of them and they stay that way.
                            • DeanR
                              • Jan 2005
                              • 1499
                              • Finger Lakes NY
                              By that, do you simply mean to back it's setting way down before putting away? Or is there something else to do as well.
                              80 SG
                              81 SH in parts
                              99 ST1100
                              91 ST1100
