Gear oil checking
  • dbmb0416
    • Jun 2015
    • 128
    • Westdale Ny
    Gear oil checking
    Hey guys. What are your thoughts on intervals for checking levels on middle and rear gear oils. Before every ride? Before long ride? 100 miles?Have had problems with both and paranoid now and will probably check before every ride till paranoia goes away. Thanks
    79 XS11SF
  • TADracer
    • 1417
    • Kenner, Louisiana USA
    I do not think you should be losing any oil from final or middle gear. If the level keeps going down there is a prob. somewhere. I check mine at each oil change.
    Mike Giroir
    79 XS-1100 Special
    • dbmb0416
      • Jun 2015
      • 128
      • Westdale Ny
      Middle leaks a little by gasket. Very little. Rear was completely empty with no leaks visible and it locked up last week. Changed out now and will be test driving this evening.
      79 XS11SF
        Yeah, I check at the oil change, to be sure I don't over-fill it. Other than that, I never feel the need to check it. If you're leaking from the middle or final drive, you have some issues to fix. Keep an eye on it, and if the level drops at all, it's time to take them apart and fix or just replace them. Plenty of folks who have switched to the 750/850 final drives probably have the originals laying around.
          Having it previously lock-up on ya' and then finding the drive empty, I'd be a bit apprehensive of it locking up while riding. Locking up could of partially been attributed to galling of bearings. May wanna be looking for a replacement final-drive.
          • dbmb0416
            • Jun 2015
            • 128
            • Westdale Ny
            Been replaced. Had one I ordered on eBay.
            79 XS11SF
              I would start checking before every ride for the first week or so. After that, once a week unless you notice something, and then on to every oil change. Be sure to use the 75/140 synthetic for the middle and final drive. They seem to run a lot cooler with it.
                +1!.....that they do, as I've checked the difference with a laser beam thermo......less heat=less friction.
                • dbmb0416
                  • Jun 2015
                  • 128
                  • Westdale Ny
                  Thanks guys. I checked before ride today. Only went 2 miles and only 30mph in third gear. It's got me skiddish from the lock up last Friday. I will check it tomorrow before taking her up to 55mph and to a Antique bike and car show. Putting her in.
                  79 XS11SF
                  • dbmb0416
                    • Jun 2015
                    • 128
                    • Westdale Ny
                    Over 150 miles and no leaks or problems. Found the leak on gear box as bolts needed to be retightened. Final drive level spot on. Now I get to enjoy her without worrying.
                    79 XS11SF
                      Sounds as if external leak was an easy fix.
