Haven’t read anything that’s similar to this problem so putting it out there to see if anyone has run across something like this in their troubleshooting. I recently picked up a 1980 SG that sat for an extended period of time and was said to run when parked. PO had a good story for the scooter and 2nd gear repair had been done. Got it home and did compression test readings and found 105 to 108 across the cylinders. Low, but acceptable to me as my 1980 Standard was 110 and ran very strong. Can’t remember for sure, but a couple of the plugs were sooty when pulled. No indication of catastrophic problems though. Pulled the bowls and found NO varnish or residue. Fresh fuel, new battery, clean plugs and it fired up. Bike ran with normal power off and on, pulled well through the gears and it seemed to be healthy enough to continue on. A local tech friend cleaned the carbs and the only thing odd he found was a mismatched needle and seat on #3. Put in new bowl kits, set the floats at 23mm, and synced them in. Still have misfires, mainly on #3 and #4. The plugs are not gas soaked, but have carbon on them. It will start easily and idle like before the carb work, and runs about as it did earlier. Now it also has a problem returning to idle after blipping the throttle as well. No vacuum loss or boot leaks. I trust the work and skill of this 20+ year tech so hear out the ignition test results before directing me back to the carbs.
Power at the TCI is 11v and the pickup coils read out 722 and 728 ohms with the tug and jiggle step. Wiring splice was very well done; in fact the whole wiring system looks like it has been well attended to other than the fuse box upgrade which I will do before I button it up. When I checked the ignition primary it read 9.8 and 10.3 ohms at the TCI. Way out of spec so I thought I found a problem and pulled the coils for a closer inspection. With the coils isolated the primaries read 1.6 ohms each and the secondaries were 15.2k and 15.4k minus the caps. Caps tested at 5k. I plugged the coils back in and got 14 ohms at the TCI for the primary this time. Long story short, multiple checks for primary resistance at the TCI with coils hooked up ranges from 9-15 ohms and the coils bench test at 1.6 ohms. The schematic shows the primary wires from coils to TCI as a straight shot and both wires show no resistance when tested. How can the coils read 1.6 ohms unhooked and then 10+ ohms when put back in a single wire circuit?
I haven’t ran the bike very long at one time, but it did “catch hold” on occasion and indicated it really wanted to go. The sooty plugs not being soaked and the coil reading at the TCI are what I think make this an ignition issue. Any advice from the gurus?
