Precarious Journey: Forks, Wheel, or What?
  • mesmeridicus
    • Sep 2013
    • 74
    • Dayton, Ohio
    Front tire went flat on me while I was riding the bike recently and I put her down. Luckily, I was in a neighborhood at the end of my trip and I wasn't going too fast.
    Removed front wheel and took it to the shop that had mounted the tire last year. They told me the bead must've just gotten dirty (strange, since I'd put less than 200 miles on the tires) and that's what caused the leak.
    Anyway, I reinstalled the front wheel myself. Unusually difficult, given that I've changed the rear wheel with ease. I did, however, leave the front fender off, as I liked how it looked.
    Just took the bike on a trip from Dayton to north of Columbus and then all around near Athens with my cousins for a few days. Noticed that it felt precarious in turns, and was wallowing a bit. Like a wobble, but not in the handlebars. Found myself having difficulty keeping up with them as they were able to take turns with more speed and more smoothly than myself. I had one cousin ride the bike to see if it was just me lacking confidence since the drop, but he felt it too. Ever since I got home I've been trying to pinpoint the issue. I will note that I kept my tire pressure at spec throughout the trip, so this is not the issue. Additionally, the tires are still fairly new. Around 1000 miles, tops.
    Could I have misaligned the forks or the wheel when I put it back on? The forks aren't noticeably bent, and neither is the wheel rim as far as I can tell. I've reinstalled the fender to see whether perhaps it's a lack of stiffness in the forks causing the issue.
    Any help is appreciated.
    Also, possibly related: does anyone who owns a 79 Special have a spacer on the outside of the forks, just inside the castle nut (castle nut >> spacer >> fork)? Wondering if I accidentally put it in the wrong place and it goes inside the forks. I can take a picture if necessary
    79 SF
    Hi mesmeridicus,
    Corrosion of the wheel in the bead seating area is a quite common cause of a slow leak. Did the shop clean up that area or just remount?
    I have had the valve stem leak too. Test with soapy water and a turn on the nut might seal it. if not replace it as the rubber gasket on the inside hardens over time. Mine is a Standard but it can be tricky to get the forks and calipers all lined up correctly. Over torque of the axle nut can upset the alignment too.
    Has taken me 3 tries on occasion
    After going down you need to check the forks straightness.
    Many install a Fork Brace as the fender alone is not enough so put the fender back on. Check the wheel bearings too.
    Glad you survived your tumble.
    • ViperRon
      • Feb 2011
      • 1062
      • Woodstock, VA
      Check your air pressure in tires if the gauge you use is bad and pressure is low especially with no fender support it can wallow like a pig in the corners.
      Rodan
      1980 G Silverbird
      1198 Overbore kit
      Grizzly 660 ACCT
      Barnett Clutch Springs
      R1 Clutch Fiber Plates
      122.5 Main Jets
      ACCT Mod
      Mac 4-2 Flare Tips
      Antivibe Bar ends
      Rear trunk add-on
        Hmmmmm..........try holding one upright when your tire goes down at 70 - 80mph. Happened to me in Arkansas on the way to XS Southeast a few years back. Didn't go down but I saw every part of my life flash before my eyes in less than 30 seconds.
        You post is a perfect example of why you need to stay on top of your tire pressure and a lesson to those that want to run around without a front fender.
        We haven't heard much from those that delete the front brakes......
        I wonder why?
        • GLoweVA
          • Jun 2011
          • 1957
          • Virginia Beach, VA.
          Yep, missing fender. It acts as a fork stabilizer. Some of us even add a fork brace to stiffen up our front end.
          80G (Green paint(PO idea))
          The Green Monster
          Got him in '04.
          bald tire & borrowing parts
          Scarlet
          Got her in '11
          Ready for the twisties!
          81H (previously CPMaynard's)
          Hugo
          Cold weather ride
            While you're at it, have a look at this old thread dealing with some front end troubleshooting.
            For lots more, use the terms 'steering', 'head', and 'tight' in the search tool to get more insight.
            • mesmeridicus
              • Sep 2013
              • 74
              • Dayton, Ohio
              Hi mesmeridicus,
              They cleaned the rim and remounted the tire. Leak was definitely on the bead, I used soapy water to figure that out before I took it in. I used a torque wrench on the axle nut so I know that it's to spec: wondering whether I placed a spacer in the wrong spot though. It's on the outside of the forks, in between the castle nut and the left fork.
              I'm looking into a fork brace (emailed TKat). Thanks for your help.
              I wonder why?
              That sounds like a harrowing experience. I'm glad I was in a neighborhood.
              So, I stored the bike in a buddy's garage over the winter. The day I took it out, I inflated the tires to spec, no issue. Drove it home, and then left it outside for an hour before heading over to another friend's house. His house was less than a mile and half away, and it was in his neighborhood that this happened. I had inflated this tire less than two hours earlier, I had no reason to think it would deflate while riding, and on such a short trip. That said, I think you're exactly correct -- I learned that lesson pretty cheap.
              Do you think the lack of a fender is enough to cause the symptoms I experienced on my trip, detailed in the first post? If it's just the fender, I've already put it back on and I'm waiting for a day with no rain to give it a test. I hope it is just the fender.
              Thanks everyone for your advice, I'm going to ride it with the fender ASAP to see if that's what was causing the issue. Any other info or advice is greatly appreciated. This board is an invaluable resource.
              79 SF
              • JasonRedbeard
                • 109
                • Tuscaloosa, AL
                I give it 85% odds that the fender will sort your wobble. The other 15 I'll chalk up to a slightly bent fork.
                My Special is as old as I am.
                  There is supposed to be a 2mm thick washer behind the castle nut, not a spacer.
                    'tire pressure at spec'........meaning what? Use tire manufacturer max. spec on side of tire, not bike manufacturer spec. You need to be running 40-42psi in both front and rear tires, and is normally what max.psi spec. is on side of tire. If your lookin' for a way soft ride, by a Caddy.
                    • mesmeridicus
                      • Sep 2013
                      • 74
                      • Dayton, Ohio
                      That's encouraging to hear, thanks. Fender is reattached so once this rain quits I'll take it out and push it.
                      Not mechanically apt myself. Thanks for the correction, and letting me know it's in the right place.
                      Oh, whoa. I've always run front around 34 and rear around 36. Sometimes 36-36. I should be pressurizing both tires to just under their max factory spec as per what's written on the sidewall of the tire? I guess that will make a difference in handling as well. Maybe I'll try 40-40 first. I don't give a damn about a soft ride. Thanks
                      79 SF
                        Again.....max as per what is on sidewall of tire.
                        • MindWebs
                          • May 2009
                          • 431
                          • Baldwin, WI
                          try this... (hold my beer)?
                          if you are wondering what the stiffness is between fender and no fender,
                          that we can measure!
                          simple experiment.
                          have a buddy help,
                          with out the fender on, stand facing the front of your bike, straddle the front tire.
                          use your legs to "hold" the front tire stationary, grab the handlebar grips.
                          now turn the bars as far as you can while holding the front tire from turning.
                          have your bubby use a tape measure from a setpoint (edge of gas tank to one of the handle bar ends) take a measurement from "at rest" then from "turned".
                          install fender and repeat.
                          install fork brace and repeat.
                          my "guess" is that the fork deflection (twist) will be cut in half with each part you install.
                          if you want to run without a fender(your bike, your neck, your option)
                          i would add tkat's fork brace and that will stabilize the forks to make them safe to ride. personal taste is fine and good but please be safe.
                          we like having people to bs with.
                          also pull up bike bandit and look at the exploded parts diagrams.
                          they are very helpful if your not sure of assembly order.
                          I use them ALOT!!!
