So I have three banks of carbs sitting in front of me and all of them having something wrong with the third carb...the cursed one it would seem. Is it possible to swap out the third for a first carb? I know the second and fourth are out of the question because of the vacuum advance. Thanks ahead of time!
Carb swap 1 and 3...possible?
1 &3 can be swapped if you change the linkage and if you put 1 in 3's spot you'll need to drill and tap the hole for the idle speed screw. I've done it but the only place I could find the correct tap was online from China.
3 can be swapped for 1 with just a linkage change though.Greg
........forgot your famous comment Greg......"#3 carb IS the evil carb"81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.Comment
I completely agree with the titling of evil on that third carb....let the exorcism begin! I looked at the threading and you weren't kidding....that is super fine! You wouldn't happen to have handy the information for what you ordered?79F with two parts bikes (78E and a 79F). Ran it for the first season all the way through the summer.
more work to do this Spring!Comment
