Manometer tutorial (Carburetor Synchronization)
    Some of you may already be watching the Hackaweek Youtube channel. The April 2 edition has a very good tutorial on building a manometer and using it to sync the carbs on a CB750.
    73 Honda CB750 Custom Build Episode 35 - Carburetor Synchronization
    He should have put some small orifices down near the carbs, but I'll leave that for your comments. This may help or motivate someone.
    • 1262
    • Peachtree City, Georgia.
    Marty,
    That guy obviously knows his stuff. There are some good tid-bits in his explanation of the relationship between carbs when one is adjusted the others changing slightly.
    HOWEVER, the apparatus he built: gauges he said he bought on Flea-bay for $7 each ($28), probably $10 worth of PVC parts, $10 worth of fittings +/-, air hoses, homemade adapters for the Honda Carbs, misc. supplies (Zip Ties, Hot Glue, Etc.), +LABOR TIME TO ASSEMBLE. He also uses a tool "MOST" do-it-yourselfers probably don't have, 1/4" NPT pipe tap.
    I paid <$60 for my EMGO 4-Carb set complete with all the adapters he made & in-line valves to eliminate the "bouncing needles" he built the PVC tubes for. I think he spent more for his set-up in parts?
    Thanks for the link.... The guy is informative...
    KURT
    1982 - CBX1000 - Honda
