unknown plugs
  • MadHatter4119
    • Nov 2014
    • 137
    • Baltimore, MD.
    unknown plugs
    Hi All...I found two (2) different electrical connections, one 5 small male prong and the other if a 6 round female connection under the seat that are
    not connected to nothing...For the life of me , I can't figure out how to post
    pictures...I think I can shrink them on my computer...but can't figure out how
    to attach them to this post...????????
    79 XS 1100 Special "Basket Case"
  • dpotter58
    • Aug 2004
    • 1866
    • Southern Maryland
    you need to save the pictures to somewhere like photobucket then you can post them here.
    1980 LG
    1981 LH
    • Eastcoaster
      • Jan 2012
      • 513
      • oceancity NJ
      heres what you need
      82 XJ1100J
      81 Venturer
      • MadHatter4119
        • Nov 2014
        • 137
        • Baltimore, MD.
        So I'm missing the cancelling unit and light checker unit...Whatever that
        is...???
        That's easy for you to say about posting picture...this is the first forum that I have joined that you can't
        post pictures from your computer...I guess that's why a lot of post don't have pictures even when they
        are needed...
        • Eastcoaster
          • Jan 2012
          • 513
          • oceancity NJ
          Yup Heres your plugs
          82 XJ1100J
          81 Venturer
            Round plugs????
              You don't need the light checker unit, it is only there to tell you if your tail light bulb burns out. Jump the blu and blu/yel wires together to bypass. The other unit is the signal cancel unit, the signals will work normally without it there, just no self cancel.
              • MadHatter4119
                • Nov 2014
                • 137
                • Baltimore, MD.
                Round 6 prong female connection...What goes into those connection...and what are they for...? its a 79 XS 1100 Special it starts ok now without them
                ...I just got it running today...Haven't driven it yet...
                • MadHatter4119
                  • Nov 2014
                  • 137
                  • Baltimore, MD.
                  Thanks Biker Phil...I check my brake & tail light often enough to suit
                  me and I may have the cancelling unit...I wonder if a 82 Virago 920
                  cancelling unit would fit...should have a few of them around here...?
                  We will see if I don't have the stock one...
                  • MadHatter4119
                    • Nov 2014
                    • 137
                    • Baltimore, MD.
                    I just tried that photobucket...did something wrong...No photo...I'll check out YouTube and see if I can find some info on how to post picture from there to here...they have every other kind there...
                    • MadHatter4119
                      • Nov 2014
                      • 137
                      • Baltimore, MD.
                      This issue can be put to bed...Thanks To All
                        Hey Harry,
                        You tried to copy the web page url, that's how I found and viewed your photo album...all 3 images. The above 2 were in your album, but Gordon put them into HIS album to post for you?
                        When I view your album, I don't the little text window along the bottom of each image like I see when I view "MY" account albums....but hopefully when YOU view your album, you'll see the text window along the bottom of each image. You click on that window, it highlights the text, then just COPY.
                        NOW, if you don't see the little text window...then hover over your photo, you'll see 3 horizontal bars pop up, then 4 text command choices...select SHARE. Next, you'll see the text window that has the URL in it, but it also has a lot of other unnecessary text as well. IT'll look like this......
                        [ URL=http://s1268.photobucket.com/user/harryd4119/media/IMG_2106_zps05evzqum.jpg.html][ IMG]http://i1268.photobucket.com/albums/jj571/harryd4119/IMG_2106_zps05evzqum.jpg[/IMG ][/URL ]
                        I've put spaces so that you can see the whole thing as text. The part you want to keep it the [ IMG] front/beginning and [ /IMG] ending tags and the text in between...Delete the [ URL ] parts.
                        So you're left with .....
                        [ IMG]http://i1268.photobucket.com/albums/jj571/harryd4119/IMG_2106_zps05evzqum.jpg[/IMG ] again, extra spaces so you can see the text, and then below is the actual photo directly linked to YOUR ACCOUNT showing in the message!
                        • MadHatter4119
                          • Nov 2014
                          • 137
                          • Baltimore, MD.
                          TC...
                          Thanks for all your efforts to explain photobucket...To be honest, it's all
                          greek to me...I take my icon and hover over the picture and nothing pops
                          up...on the picture is three (3)white bars...I click on the bars another window
                          opens...it has a share link...I click on share and another window opens up and
                          none of it is user friendly...Crap...I'll check YouTube to see if someone posted
                          a PhotoBucket How To video...It may make sense if I seen it...???
                            TC...
                            When that last larger window opens up with the links, left click on the IMG code and it will turn yellow and say "copied"
                            Go back to your post on .com and put the flashing cursor bar where you want the pic to be in the post. Right click and a small window will open and give the options of undo, cut, copy, paste, and a couple other things. Click on paste and the IMG code will show in your post. That code will show up as a picture when you submit your post.
                            You can preview it by clicking on the preview box below your unsubmitted post.
                            • Eastcoaster
                              • Jan 2012
                              • 513
                              • oceancity NJ
                              check your email
                              Harry
                              Check your email and text just sent you a tutorial on how to post pix
                              Hope it helps
                              82 XJ1100J
                              81 Venturer
