Fuel inlet tees on the carbs,
    anyone tell me where to get some new replacements or tell me how to fix these leaky %$#*&@'s.
    Partzilla has them new but @ $45 per.
    • 1262
    • Peachtree City, Georgia.
    Repair with O-Rings
    Greg,
    I believe it might have been MARTY that posted a how-to where he removed the hardened crap on the tee and then put a row of several HF O-rings on the tee. I also read some other post that another guy had followed those instructions and had success.
    KURT
    1982 - CBX1000 - Honda
      I sorta kinda remember something like that but I looked in the repairs section and nothing.
      Whenever I try to use the search function here I end up having to go through 4K posts to find what I'm looking for if I find it at all.
      So, I just ask.
      • Prisoner6
        • Aug 2013
        • 1184
        • Phoenix, AZ
        Here you go, Greg:
        Carb Tee Repair
        Marco
        1979 Honda CBX
        2002 Kawasaki ZRX1200R
        WE MISS YOU, DON
        • tomcos67
          • Apr 2015
          • 311
          • Amsterdam, N.Y.
          So, I just ask.
          It's OK .!You can ask.!
          1980xs1100.sg Pacifica Fairing ..stock.
          2006 Honda Shadow Spirit 1100.! ⛺
            The bigger one.
            Smaller one.
            Neither is cheap but the are all brass with replaceable orings for the future. It is what I will get when I need them.
              Originally posted by Prisoner6
              Here you go, Greg:
              Thanks. Hmmmm ........lots of o rings.
              I will anyway but it IS nice to have permission.
              Originally posted by natemoen
              The bigger one.
              Thanks Nate, the bigger ones are for the fuel, smaller ones are the bowl vents. I have a couple of those that fit snug, I'm thinking of trying those.
              I found a video that Mack made, may try his method also.
              Thanks for the responses y'all.
                • 2104
                Repair
                Remove the area between the original raised o-rings:
                Add two new o-rings to each side lube with silicone grease and install
                  Thank you gentlemen. I'm on it tomorrow.
                  • Bartman
                    • May 2012
                    • 200
                    • Jefferson, Georgia
                    The o-rings might still leak for a minute until they swell. Several times I have had the carbs apart and back together and found leaking gas from this mod/fix. Give it 20 minutes before cussing and tearing it back apart.
                    79 XS11
                      That's where I was with these tees. They always swelled and stopped leaking before. Messed with them for 3 hours today and they weren't just leaking, they both were pouring.
                      • mack
                        • 2411
                        • Ontario, Canada
                        Carb T repair
                        This works good greg and alot less washers. If yours don't stop or you've ruined yours already. PM me and I can send you down a pair.
                        mack
                        79 XS 1100 SF Special
                        HERMES
                        original owner
                        81 XS 1100 LH MNS
                        SPICA
                        78 XS 11E
                        IOTA
                        https://youtu.be/wB5Jfbp6SUc
                        https://youtu.be/RaI3WYHSuWA
                        Frankford, Ont, Canada
                        613-398-6186
                          Thanks mack, I've already got it done. I used Schming's method with 2 orings between the 2 raised shoulders on the stock rubber. I just finished putting them back together.
                          They feel good now, nice and snug. They were just flopping around before.
                          I'll get the carbs reinstalled after work, check for leaks and resync.
                          Thanks again everyone for the responses and the pics. Just the kind of ideas I was hoping for.
                            Back together and synced. No leaks.
                            Thanks.
                              • 2104
                              You're Welcome
                              Glad it worked for you Greg
                              I used that method on Jeff in Tampa's carbs when I rebuilt them and no leaks either so I figure that fix is a keeper
