Originally posted by JRealHEMC
View Post
Transmission issues...
Keep the shiny side up
1979 XS1100SF
Mac 4-1
Drilled airbox Uni filter
Vmax bars
Virago 1" shorter shocks
30K miles
http://i1228.photobucket.com/albums/...429_135845.jpg
1981XS1100SH
'80 G Forks and Triple Tree
'80 G tank
Mac Turnouts
Virago 1" shorter rear shocks
SH Headlight
http://i1228.photobucket.com/albums/...psd6adaae1.jpg
61 Wife
83 Son
86 Son
89 Daughter
Hey there Tweeleft,
Your symptoms are the classic gear skipping, and it won't lock up on you, but the skipping will eventually get worse, more often, and under less throttle load, and may also eventually occur to 2nd gear as well, that's what happened to my 81SH. Recently in another thread Scott/3Phase postulated that the early models 78-80 that had the kick starter gears/equipment helped to stabilize the 1st gear wheel, and so that's why 2nd seemed to fail first, whereas in the 81-82 models where the kick starter gears were eliminated, this allowed the 1st gear wheel to wobble a bit more, and so allows it to wear a little earlier than the 2nd gear, and so starts skipping first. I've seen it on mine, and a few XJ11's as well, and so it makes sense to me.
Bottom line, take it easy in 1st, shift to 2nd and above, and plan to perform the dremmel fix during the winter. My repair I did in 2000 has lasted for 16 years and some 25K miles, but just this summer started to exhibit the skip again in 1st, so I'll be going back into the transmission again to repair it again.
T.C.T. C. Gresham
